Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Somewhat of a problem, I guess it's the power supply.
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Somewhat of a problem, I guess it's the power supply.
Hello,
as you probably understood from the topic: I have a problem, I bought new hardware components and a new case, basically a completely new system, except the hard drives.
Now, after the hard work of setting everything up correctly my computer shuts down after ~1 minute of running.
I can rule out any viruses/worms since everything worked perfectly fine on the previous system.
Components are as follows:
Motherboard: Asus P5K Pro
CPU: Intel Core2Duo E8400
Graphics Card: MSI GeForce NX8800GT 512MB (overclocked)
Memory: Supertalent unbuffered DDR2 Dual Channel Kit (2GB)
PSU: I have no name but it has 430W
Case: Antec P182
Now, as I said before, I think that the problem is the PSU since I have no idea what else could cause the problem.
I would really appreciate if somebody could help me out, I lived through 5 months of instant noodles to save up enough money for all the components+case as listed above and now it doesn't work :heink:
Thanks in advance
ItsSleepy
Sponsored Links
Well you have a no-name 430w power supply running a relatively high end video card... you should replace your power supply.
------------------------------ Exchange Engineer - Why is it that when DNS goes down everyone thinks it's my exchange server?
Oh ya, email is the heart of work.
Reply to boonality
I agree with boonality. Your problem IS probably the PSU, especially if it was recycled from a previous build.
Reply to jsc
Argh, that's what I was afraid of, because it'll most probably mean another 100€, and that as a student who just moved abroad, meh.
Thanks for your answers, I didn't want to rush to the next computer store and get myself a new PSU for ~100€ on case I missed something, but that's solved now.
Reply to ItsSleepy
It looks like you are using the stock heatsink. Be sure it's mounted properly or it will overheat and shut off. The pins need to be securely connected to the mobo. There are a 100 threads on this.
Message edited by Zorg on 04-09-2008 at 12:24:35 AM
Reply to Zorg
Yes, I do use the stock heatsink, the pins are all in place (even though at some points I thought I was about to break the mobo), the fan is connected to the cpu_fan connector and works very well with the antec case.
One thing which was strange was that in bios the hardware manager displayed a cpu temperature of 72*C which is absolutely impossible.
I had my computer switched off for around half an hour, then started it, immediately went into bios to see the temperature and it said 73*C after running for ~15 secs, so I opened the case and touched the heatsink (of course after switching off all the power and stuff) which was not even remotely warm...
Reply to ItsSleepy
If the HS isn't properly fastened the CPU will get very hot but the HS will remain cool. Make sense? Reseat the HS again before you boot again. When a CPU reaches thermal shutdown temps it's very hard on it.
Reply to Zorg
Alright, I'll try that, but first I'll catch some sleep and check back tomorrow, thanks again.
Reply to ItsSleepy
Hm, tried to edit it but was not allowed to...
I reseated the Heatsink and I could fasten it with way easier than before.
It works fine now, no shutdowns anymore.
Thanks a lot, you saved me quite a lot of money there, I really appreciate it :D
Reply to ItsSleepy
Happy to help.
Reply to Zorg
By the way if you are using a no name PSU then you should change it for a name PSU. Not any name either. There are a lot of threads on this, or I can steer you to a good one. Only if you like your new rig though.
Reply to Zorg
Toughpower... I like my thermaltake toughpower 750. I also like my Antec, though.
Reply to hairycat101
He probably won't be back until his machine really fries.
Reply to Zorg
There are 1312 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
