News
Electronic Arts to Sell Crysis-branded PCs
Published on July 30, 2008
EA plans to make sell PC purpose-built to run Crysis Warhead Read more
Thermaltake introduces NAS-RAID drive storage system
Published on July 28, 2006
Thermaltake introduced its Muse N0001LN NAS-(Network Attached Storage-) RAID drive storage system. Read more
Built-in 3/3.5G may be next big thing in notebook market
Published on December 08, 2006
Communications chip suppliers are eying the huge business opportunities promised by notebooks with built-in 3/3.5G modules. Read more
Microsoft to Do Ads in Blizzard Games
Published on December 04, 2008
Video game advertising company Massive, owned by Microsoft, just struck a deal of name appropriate proportions with Blizzard Entertainment. Read more
Latest Reviews & Articles
Best Graphics Cards For The Money: Jan. '09
Published on January 07, 2009
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Scorpio Blue: Big Notebook HDDs Go Mainstream
Published on January 06, 2009
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
Value In SLI? GTX 260 Core 216 Vs. GTX 280
Published on January 05, 2009
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
System Builder Marathon: Performance & Value
Published on January 01, 2009
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
  Tom's Hardware Forums » Homebuilt Systems » General Homebuilt » massive lag with new built system (arg)
Word :   Username :
Bottom
Author
 Thread : massive lag with new built system (arg)
Profile: journeyman
More Information
Hello everyone. I was recently helped on the forums on buying a new comp for my friend, well he recn;ty got it with only onr change the site was out of the 8800's so he went to the 9600gt's and he is experencing massive lagg and freezing. here is the list of comp's
Motherboard - ASUS P5N-T Deluxe LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard - Retail
$259.99
Processor -Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600
$275.95
(this processor or E8400)
Power Supply -PC Power & Cooling Silencer 750 Quad (Black) EPS12V 750W Power Supply - Retail
$269.99
Heatsink - Thermalright Ultra-120 CPU Cooling Heatsink - Retail
$59.99
Fan For Heatsink - Scythe S-FLEX SFF21F 120mm Case Fan - Retail
$24.99
Thermal paste - Arctic Silver 5 Thermal Compound - OEM
$5.99
Ram 2 gig - CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400C4DHX - Retail
$92
$92
EVGA E-GEFORCE 9600GT Ssc 750MHZ 512MB 1.95GHZ DDR3 PCI-E Dual DVI-I HDTV Out Video Card
Sound Card - The onboard 8-channel HD audio
$0
HDD for Storage - Western Digital Caviar SE16 WD5000KSRTL 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - Retail
$119.99
DVD - ASUS 20X DVD±R DVD Burner with LightScribe Black SATA - Retail
$35.99
OS - Microsoft Windows XP Professional With SP2C - OEM
$139.99
Case - Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
$109.99
Any idea what is causing this? I have updated his vid card drivers, have all win updates, and have zone alarm with antivirus. I would take a look at it but im in the USA and he is in CANADA so all I can do is remote assistance.
Related Product
Profile: Forum Veteran
More Information
Clear cmos, enter bios, load defaults, save & exit.
What's the monitor resolution?
Try low to medium in-game video settings.
Where do these lagging & freezing occur?
If he installed ActiveArmor or nvidia Firewall, uninstall it.
If he installed ntune, uninstall it.
Update windows & drivers.
Profile: old hand
More Information
Did you install all the mobo drivers off the cd that came with the board ?
And is the memory set right in the bios ?
The load optimized settings above might help there.
Did you open the device manager and look for anything with a ( ? ) next to it ? That would mean a driver update is needed.
Did you try and run the machine with one card ? Or with just 2gig of memory ?............. in the correct slots.........
Profile: journeyman
More Information
Ok I need to clarify it is lagging in games but, it will lag or freeze in the middle of just sitting on the desktop. I will check his mobo drivers and see if there is an update. I will also check out his bios and make sure everything is correct. He bought this system from NCIX.com and they put it together and tested everything for 3 days they said. (lol) In addition, I already check his device manager because that was a symptom of not having the smbus driver installed on another friend’s machine but not here. Everything in device manager is ok.
Profile: journeyman
More Information
edit i will tell him to try with only 2 gigs and then if its still lagging i will tell him to remove the other card.
Profile: old hand
More Information
CPU cooler seated properly? Case ventilation good?
-mcg
Profile: Eternal Poster
More Information
Can you post pictures of CPU-Z screenshots?
Scruze my English!
Profile: journeyman
More Information
ill get a cpu-z screenshot. yep cpu cooler is seated properly.
Profile: addict
More Information
The way you worded your post ("he recently got **it**" ) "it appears that you ordered the computer spec built. If that's the situation, let the builder's TS guide you thru it.
If you meant "He recently rec'd the parts and built it", then I'd start slow with 2 GB of RAM and just 1 vid card installed. Did you read the MoBo manual, going thru it page by page ? Did you check all of the BIOS settings ? Did you install all the drivers on the MoBo CD ?
Have any diagnostic utilities ? Belarc Advisor will tell you what's being seen.....SiSoft Sandra can point out common problems.
Profile: journeyman
More Information
ive check his comp out with everest comperate edition. He bought a system from ncix.com and they put it together. I have checked everything i can think of unless the windows install did not take propely. i will ask his to run with only 2 gigs and one vid card
Profile: journeyman
More Information
k heres the scrren shot IMG]http://i46.photobucket.com/albums/f124/donald7777/cpuz.jpg[/IMG]
Profile: journeyman
More Information
ok i ran sisoft and there was nothing wrong it siad i told him to run them all and i read the results i have disabled his sli and am testing his comp from afar, hes too worryed about pulling out his ram and the bios. i tryed to walk him throught it but he wanted no part of it.
Can't. . . stop. . . upgrading
Profile: enthusiast
More Information
Mine did that when I, wait, no, a friend of mine pirated windows and it failed the genuine validation.
They call me crazy for yelling, alone in my room, at the computer screen. They just don't understand the game.
Profile: journeyman
More Information
sorry but the xp pro is real, it passed guninue vantage test plus he has the xp pro sticker. i don't think ncix would put pirated software on their systems.
Profile: journeyman
More Information
edit problem may be solved just waiting. what i did talked him into unpluging mem and vidcards plugging them back in. changed his renderding settings to alternative and multi gpu with single display.
Profile: journeyman
More Information
ok most of the problem is solved except bf2 woun't install now. It get past the lang selection but then disapers off the screen and task manager. Any idea's I changed the sli configurationback to normal to install but did not help.
More Information
