The Serial ATA International Organization (SATA-IO) has announced that it is working on a new specification that will provide power to external SATA (eSATA) devices without the need for a separate power connection. Read more
OCZ Technology Group has introduced a new modular power supply with a sustained output of 600 watts. The PSU will hopefully lessen cable clutter because only the necessary power cables need to be attached. The titanium mirrored case comes with two PCI-Express cables and a 4/8 pin CPU auxiliary fan connector. Read more
Tributaries just introduced its T12 power strip which promises to solve a common tech problem of "I can't fit all my power adapters on one strip." While we usually forward the press releases into a virtual recycle bin, this product caught our attention as it finally solves some of headaches we experience on daily basis. Read more
Consulting company Kagan Research believes that consumers will spend substantially more money on services provided by their cable company in the next years. Read more
Core i7--previously referred to as Nehalem--requires new motherboards, coolers and memory. Its performance is compelling and means AMD is falling behind even further, but Intel is putting in some speed bumps that will impact overclocking enthusiasts. Read more
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
Tom's Hardware Forums »
CPU & Components
Power Supplies, PC Cases & Case Mods »
CPU fan can't fit in the socket, the power cable takes up the space
| Bottom | |
| Author |
Thread : CPU fan can't fit in the socket, the power cable takes up the space
CPU & Components
