I'm in a bit of a problem. The jumper where you connect the on/off switch on my mobo has stopped working, I've tried several different switches with it. There's nothing visually wrong with it, what can I do? It was working fine the last time I rebooted although this was several weeks ago.
The motherboard is receiving power, the LED on it is still lit up just fine, do you think I will have to hotwire the powersupply? Thanks for your help in advance!
Ahh I figured it out, the power supply messed itself up. tried a different one out and it turned the board on, too bad the wattage is too low to run everything, guess I gotta go pick a new one up real quick like.
