Tom's Hardware > Forum > Overclocking > CPUs > HELP! with my overclocking plz
Forum Overclocking : CPUs - HELP! with my overclocking plz
Ok, so I have a AMD Phenom 9600 2.3GHz Quad processor and a ASRock A780GXE/128M AM2+/AM2 AMD 780G ATX AMD Motherboard and Vista. Basically my Asrock mobo came with a nice tool called OCtuner which allows me to easily choose my overclock settings w/o Bios. well my computer detected that my CPU was at 2.29GHz standard and I used this tool and moved it up to 2.35GHz (235MHzx10) and it said and showed on the tuner that I was at 2.35GHz but under my "Computer information settings" (right click on my computer) it still says I'm at 2.29GHz. Plz help me! did my overclocking work?
Sponsored Links
download cpu-z, it tells you what your frequency is currently, if you are looking at where i think you are, that is the speed that it detects and keeps when you boot up, it doesnt update itself, i would also recommend learning to overclock in the bios, it is more professional and there is more to tweak when you get more used to it, be careful using software overclocks, it could also push your ram at the same time, and could fry it, also keep your eyes on your temps, run prime95 to test stability if you wish
Reply to SanDiego
Stay away from OCing in windows using software. I tried that before I knew better and its not usually stable. BIOS is the only way to go and if you dont know how then start reading.
Some motherboards dont OC well so try to google search your mobo to see if anyone has OC'd it with success.
Reply to englandr753
I recommend reading this wonderful tool called "STICKIES". It is designed for people new to overclocking that don't have too much knowledge of it. Read that please, then come back and ask more specific questions. Thank you :p
------------------------------ Antec P182, i7 920 3.8Ghz @ 1.325V, Xigmatek 1283, Asus P6T X58, 3 x 2048MB OCZ Plat DDR3 1600 RAM, 2 EVGA GTX260 Core 216 in SLI, WD 160gb,320GB 1TB WD Black. Corsair 750TX. Acer 24" Monitor. Vista x64 Home Premium.
Reply to one-shot
There are 1202 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
