Tom's Hardware Forums » Homebuilt Systems » General Homebuilt » Help deciding which components to upgrade
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Help deciding which components to upgrade
Profile: stranger
More Information
After having to resort to medium graphics to get playable framerates and in the case of some games which I can't mention I can't even run 25+ fps with medium settings.
Here are my specs.
EVGA 680i LGA 775 SLI motherboard
BFG 7900 GS ( I am definitely upgrading this )
2gb corsair dominator ( I tried putting 2 more gigabytes of the same speed + timing but different brand and they don't play nice [both work/boot but not together] so I would have to go 2 x 2gb in this situation )
160gb SATA HD ( I cannot use IDE )
Typhoon CPU cooler
Intel core 2 duo E6400 running at 2.6 ghz each core very stable ( only 50 c under maximum load, 43c idle and I literally don't have a single case fan in my computer on. The typhoon and the power supply cool my case nicely. I have 2 case fans I can enable easily which would bring it down further to
My PSU is a hiper 580 watt type R with 630 watt maximum. It is rated as SLI. I don't have any other hard drives or power sucking devices plugged in.
I'm thinking of :
4gb 2x 2gb = 70 dollars newegg.com
9600 GT = 130 dollars newegg.com
overclocking my processor to 2.8 and turning on another fan in my case.
Possibly:
Getting a seagate barracuda 500 gb only 100 dollars but I might want to wait for black Friday.
I will be running vista so I can network with my 360 so I will probably need 4gb for ultimate.
Later I will be running 2 9600 GTs together in SLI but the sale only applies to 1.
Related Pr oduct
Profile: nimble knuckle
More Information
An option, consider using 2 hard drives instead of just one large one. Then use the second drive as a backup. You can still install things on it and use it to play your games and what not from, but it's great if you have a system crash or have to reformat b/c you can just nuke the C: drive and leave your secondary drive and it's data in peace. I loved doing that back when I was using all my ide drives. Made reformats so much more painless.
Profile: stranger
More Information
Anyone else? I think this is the right forum.
More Information
Btw, are you going to run 64 bit or 32 bit for your OS? Like Vista 64 bit or 32 bit. Because if your going 32 bit, 4 gb of memory might be pointless.
Profile: stranger
More Information
I can go either, but I heard 64bit had more problems with software/games and I know it will only show 3.25 gigs but it will still use 4gb. I just want something more than 2gb for the long run. Should I wait till black friday to buy 4gb and just run vista 32bit on 2gb of ram and my new graphics? Or would 2gb bottleneck it.
More Information
Myself, I'm running 2gb and it's fine for the time being. 64 bit Vista might get better once SP1 comes out. You could always have it read and use the 3.25, you'd just probably never get the full utilization from it until you went 64 bit.
Profile: stranger
More Information
I heard that it does use the other 750 mb for the OS it just doesn't show it, some bug on microsoft's end which will probably be fixed. I bought a 9600 and 500gb seagate hard drive which should get here on monday. Thanks for the help.
More Information
I think it's actually having to do with the way 32 bit is set up, because it does not know how to handle all of the addressing for that much memory. But no problem.
Add a reply
Google Ads
News
MIT researchers developing a quarter-sized turbine engine
Published on September 20, 2006
MIT researchers have started putting entire gas-turbine engines on tiny silicon chips. With the help of some military funding, researchers have fashioned millimeter-sized compressors, combustion chambers and turbines and placed them on layers of silicon wafers. Read more
Intel expands network processor line
Published on October 19, 2004
With a goal of boosting already robust network processor market segment sales, Intel today announced two new families of network processor units (NPUs) for traditional communications applications and for the emerging embedded networking segment. Read more
Memory upgrade enhances performance of Fujitsu's FinePix S3 Pro digital SLR camera
Published on January 16, 2006
Fujifilm has begun offering a buffer upgrade for its 12.3-megapixel digital SLR camera FinePix S3 Pro. Read more
Renesas: 90nm dual-core MCU for automotive to hit market by 2010
Published on August 18, 2006
Renesas Technology anticipates that its dual-core microcontroller (MCU) for automotive vehicles could hit the market by 2010 at the latest, and possibly as early as 2008. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
