Hi all!
I have the following problem:
I have an E8500 running at default speed on a x48 dq6 Gigabyte motherboard with 4gb of transcend ddr2 memory running at 1066 MHZ.
Allthough I haven't overclocked my machine and allthough the vcore voltage is set to "auto" in bios (which says is 1.225 or sth like that) when I check cpuz it shows that vcore is 1.344v. In addition to all this I can't run my memory at 1066 because vista is unstable (after some time of use blue screen appears with memory management problems) but this is something normal for this mobo as I have read on other forums. If I run on 800mhz everything works fine.
Another problem is that I can't increase fsb in order to overclock because every time I do so the system reboots twice and bios takes settings back to default (seems like my system can't handle that increase).
As I read elsewhere increasing the fsb to 1600 and running e8500 on 3.8ghz is something that easily can be achieved.
Any thoughts?
Any thoughts?
