Hi..I just bought a XFX 8800GTS 512MB XXX edition. I hoped for better performance..but games like world in conflict, crysis and other 1/2 titles are jagging a lot..I got avg 18-20 fps for crysis at 1600x1200 res and 24-25 fps for 1200x1024 at all high settings..its the benchmark result ..and it goes down more in world in conflict. not sure whether its the normal scenario or my graphics card fault..or anything...GPU temperature on load doesn't cross 46C. Oh BTW i m using XP with SP2. But COD4, Bioshock, GRAW, HL-2 are just fine. In stalker I faced some artifacting problem when I changed the graphics settings within the game and after relaunching it was OK.
Also remember to kick the fan speed up manually, it presets at 32% on my card, same as yours. And if your ram is ddr400, get some 800 if the mobo will let you, But if nothing else get 2 gigs of ram, that makes a huge diffrence.
cpu and ram bottlenecks. Crysis uses 1.5gigs of ram for me on high at 1600x1200. You can add a gig of ram and try overclocking the processor, it might help, but it's probably time to look into upgrading the board, cpu and ram.
------------------------------They call me crazy for yelling, alone in my room, at the computer screen. They just don\\\\\\\'t understand the game.
Reply to jeremyrailton
yeah i would agree, time to play catchup, ask your boss for some overtime, and start researching, that way you can be happy knowing your getting the best performance at a good price.
The artifacting concerns me. Make sure your card isnt getting too hot, check your gpu fan speeds and temps, and get another gig of ram
------------------------------I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
Another vote for CPU and ram holding you back. Dam your card is worth 2 times as much as the rest of your system.
It is time to upgrade your system if you want to game. If money is an issue I recommend a P35 chipset motherboard: example Asus P5K SE $90.00 and a Intel e2180 for $79.00 and 2 gigs of Adata ram PC6400 800mhz for $46.00. Keep your PSU and DVD drive and HDD. Reformat HDD so it will run without problems on the new machine.
$215.00 and you will be kickingass compared to what you got now. You can overclock the e2180 to 3.0 real easy also.
crusoe74 said.
"Interesting you say you've got a socket 754 Athlon, I always thought that they only were AGP only."
Several manufacturers produced motherboards with ATI 480 and nforce4x4 chipsets in 754 flavor they all had PCI-e
crusoe74 said.
Hmm, 1GB of DDR, a 754 AMD 3000+ and a 1600x1200 res... thar your problem! You most definately need to upgrade your RAM. These days there is just no excuse for having 1GB when 2GB can be had for $40 or less! Upgrading your RAM should be your first priority if you don't plan on upgrading your CPU. Your CPU is simply just holding you back. I'm afraid you will need to upgrade. I'm almost certain you will get significantly more FPS even if you upgrade to something like an AMD 4400, and 2GB of DDR2. If you're still experiencing problems, then definately RMA your device. Like others have said you should not be getting artifacting though. Check to make sure your vid card is not overheating.
------------------------------E8400 3.6Ghz | 4GB DDR2-800 | HD4870 | 780GB HDD Space | VX550W | WinXP | Win7-64 | Ubuntu Studio 8.10
Reply to doomsdaydave11
I have checked GPU temp when its fully loaded but it is cool like 45-46c from CPU-Z. I think temp is not an issue. Damn my CPU is too slow and I only have 1 gig of ram..planning to upgrade my rig but also in a budget range..
Reply to jaydeejohn
