The system installs windows xp pro fine with no problems or errors, however after the install windows boots up fine then when i try to install the onboard drivers or the graphics card driver all i get is set up errors. If i try to install the drivers through the update driver option from device manager it tries but then says it can't copy the files. I have tried working memory and two different hard drivers and get the same problems. I even install Wip xp 64bit and it did the same. It also won't istall any software at all.
Any help would be greatly appriciated as i am out of ideas
Have you installed the chipset (mobo) driver before installing anything else? I know somebody with 100+ built experience should have done this. Just want to give it a try, maybe you skip it accidentally.
