Tom's Hardware Forums » Homebuilt Systems » New System Build » Need Processor Selection Help
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Need Processor Selection Help
Profile: member
More Information
I have a Maximus Formula motherboard and am wondering which processor I should buy, It is a socket 775, i want a core 2 duo or a core 2 quad. What is more stable and best for over clocking.
Note: I am not buying a core 2 extreme that costs over $1,000!!
Please post your opinions or questions bout the system.
Message edited by Coolio_Ale rt on 03-18-2008 at 03:46:10 AM
Related Pr oduct
Profile: member
More Information
I forgot to mention I will be running XP Home and this computer will be mostly for gaming.
Profile: old hand
More Information
Well, for quad you probably should look at the q6600 for best price vs. performance.  I've seen plenty of nice OCs on it.  What's your budget?
Gaming: FX-60 @ 2.81GHz (x14, 1.375, 90nm) > A8N-SLI Deluxe > Asus 4850 - 625/1986 > 2GB Corsair XMS 400MHz
2-3-3-6-1T
HTPC/Light Gaming: X2 5400+ 2.8GHz Brisbane > Gigabyte 780G MATX - 900MHz Core > 2GB Corsair XMS2 800MHz
4-4-4-12-2T
Profile: member
More Information
My budget: $200-$350 CAN im not sure if you're from the U.S. or not but the dollar is about at par right?...
(CAN-US)
Profile: old hand
More Information
Here's a thread on the topic:
http://www.tomshardware.com/forum/ [...] -processor
My original vote would be for the dual core, but after seeing how high those quads clock, you might as well go with one of them.  I think it should fit your budget.
2-3-3-6-1T
4-4-4-12-2T
Profile: addict
More Information
If you want to overclock, i mean seriously overclock, or only care about how your benchmark score looks, get a e8400. If you want to be able to play games, and have a decent amount of programs running in the background, get a quad. On air with a decent cooler a quad can over clock to 3.2 safely. Same setup with a e8400 will get you close to or past 4 gigs.
Profile: member
More Information
I heard that it is not possible to utillize the full advantages of the quad unless you're running Windows XP (which I am). I was told the full power of the quad unless you're running Windows Vista.
Profile: addict
More Information
I run dual boot, xp and vista, works great for me, i dont see a noticable diffrence between the 2 cept for one thing, i can play my older games on xp, cannot on vista, id like to say that will change when sp1 for vista is finally released, and not in danger of screwing up my comp, but more then likely no, but vista is pretty and gives me pretty toys to play with that xp doesnt...
Add a reply
Google Ads
