Tom's Hardware > Forum > Storage > Hard Disks > Help in buying a 1 terabyte hard drive
Forum Storage : Hard Disks - Help in buying a 1 terabyte hard drive
I'm going to buy a 1 terabyte hard drive for backup, and could use some help since I'm completely clueless on all the details - internal or external?
Also, I understand that the 2 recommended manufacturers are Western Digital and Seagate. Anyone here can recommend a specific model?
TIA
Sponsored Links
Internal v. External:
Internals are cheaper. If you buy from a retailer like Newegg, it will cost about $100. They also have a nice fast connection.
Externals are more expense. If you connect via USB, then it will be much slower than an internal drive. For large backup images, that could be an annoyance. A WD Black has a avg write throughput of 85 MB/s; some reviews I have seen for USB external HDDs give an avg write throughput at around 15-20MB/s (so 20 min to write a 100gig backup image file or an hour and a half). eSATA, however, solves this problem, assuming you have a eSATA port on your computer. The benefit, of course is portability. If you want an external it would probably be a good bit cheaper to buy an internal drive and an external enclosure, thus making your own.
Specific Models:
Western Digital makes good stuff. The Green edition and Black edition cost the same, one is low power, one is high performance. If you go external, then go Green edition. If you go internal then go Black.
I use Hitachi because they are cheap. I haven't had any trouble. But I would rather have Western Digital.
Message edited by gimpy1 on 05-05-2009 at 08:33:04 PM
Reply to gimpy1
I have a 1TB Western Digital Caviar Black. 7200 RPM, 32MB Cache, super stable and a 5 year warranty IIRC, all for about $110. It's the same drive as Western Digital's Enterprise Class RE3 minus the stress testing. I ripped out my old Seagate and will never look back.
Message edited by joshcatlanta on 05-05-2009 at 08:47:52 PM
Reply to joshcatlanta
Generally speaking, an external drive is ideal for a permanent back-up drive because it is portable and not tied to the computer in the event that something goes kablooey. You can snag a 1TB Western Digital external drive from Newegg for $120.
Another option is to buy an external enclosure and fill it with whatever drive you prefer, nice thing about this idea is that you can swap drives out as they get filled and external enclosures also have multiple connectors like eSATA, USB, and firewire.
Reply to chunkymonster
- 0 +
I have a couple of WD 1TB Greens for auxillary storage in one of my computers. Virtually silent. They are a little slow for a primary drive, but they are great for what I bought them for.
Reply to jsc
http://www.mwave.com/mwave/Skusear [...] ia=5177220
this guy
"WD 1tb (WDE1UBK10000N) elements external hdd 3.5" 7200rpm 8.9ms USB 2.0 (retail)"
$120
------------------------------ Main Rig ~ Q9550, Aysus P5E-VM HDMI uATX board, Sapphire 3870, XQ-Pack, Seegate 640, Seesonic 650
#2 Rig ~ E6700, 1ntel 965G uATX board, eVGA 7600GT, XQ-Pack, Seegate 320 GB, Seesonic 430 Watts
http://LASIK-FLAP.com/ ~ About LASIK Eye Surgery
Reply to Raviolissimo
- 0 +
I would suggest the WD Black internal drive.
http://www.newegg.com/Product/Prod [...] 6822136284
This drive is faster but louder than the green version. It's not as portable, as it's an internal drive, but if you wanted to take it on the go, it's not real hard to pop the side of the case off and pull it out.
Message edited by aford10 on 05-05-2009 at 10:25:46 PM
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
Depends on the storage usage. I have my dvd collection backed up on 3 1tb WD green drives i choose them cuz it wont be constally backing up so a quiet lower power drive was perfect.
http://www.newegg.com/Product/Prod [...] 6822136317
Reply to IzzyCraft
There are 801 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
