i have an a7v with a 1.3ghz athlon that i have been using for years with a pair of crucial 256mb sdram dimms (CT32m64S4D75.16t - specs are SDRAM, PC133 • CL=3 • Unbuffered • Non-parity • 133MHz • 3.3V • 32Meg x 64)
since i had another slot available i finally got around to ordering another dimm. 512mb. also from crucial (CT64M64S4D75 - specs are SDRAM, PC133 • CL=3 • Unbuffered • Non-parity • 133MHz • 3.3V • 64Meg x 64)
I plugged the 512mb dimm into the third slot (closest to cpu) and started using it. after a few days i noticed firefox was crashing, so i ran memtest86 and it indicated errors starting at about the 512mb mark.
I changed the order of the dimms, and put the 512mb dimm first and the 256mb dimms in 2&3 and memtest86 again indicated errors.
I tried just the 512mb in slot 0 and it worked fine.
I am now trying 512mb in slot 0 and a 256mb in slot 1 and so far so good.
At this point, what should i be looking at? Could this be a power supply issue?
thanks
thanks
