can a micro atx power supply power on 8800gt, 9600gt, or ati 3850
Last response: in Systems
Well, im building my own pc case to replace my old outdated xbox 360. My goal is to make a gaming pc with a case as small as xbox 1. Will a micro atx powerful enough to power on 8800gt, 9600gt, or ati 3850? If this 2 power supplys below cant handle it, what power supply is recommended? it needs to be small as possible. Current spec are:
Asus m2a-vm
Patriot 2gb 6400 Lat:4
AMD 4200 x2
xp pro
hdtv 720p
no graphic card yet
power supplys will they work?
LOGISYS Computer PS350MA MicroATX 350W Power Supply 220V FCC.UL.CUL.CE & CB - Retai
http://www.newegg.com/Product/Prod [...] 6817170015
SP Group FSP300-60GLS-MJR MicroATX 300W Power Supply UL, CSA, VDE, NEMKO, TUV, CE, CB, FCC - Retail
http://www.newegg.com/Product/Prod [...] 6817104044
or is there any very small atx power supplys.
Homebuilt system Expert
Power supply Expert
Well a Antec 380w Earthwatts could, but not sure how long it would last. Especially in a small enclosure and if the cooling isn't sufficient. See my link in my signature about the capabilities of the 380w PSU. I'm not sure about a small PSU, but I'd go with a Antec 430w Earthwatts PSU at a minimum with a 8800gt. Not sure if I'd put a 8800gt into a small case, because it's known pretty well at running hot. You could get by with a lesser PSU for the 9600gt or the 3850, since they don't require as much power as the 8800gt.
Ask the community
