Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Best single-slot solution?
Forum Graphic & Displays : Graphics Cards - Best single-slot solution?
I currently run the following...
OS____Windows XP Home SP2
CPU___AMD Athlon X2 3800+ / 2.4GHz
Mobo__GIGABYTE GA-M61P-S3
GPU___GeForce 7600GT, 256MB GDDR3
RAM___A-DATA Extreme, 2GB, DDR2 800 / 4-4-4-12, 2T
PSU___FSP Group 450W, 36A
HDD___Western Digital Caviar 250GB
Case__Antec Nine Hundred
I have only one 16x PCI-E slot available on this Mobo, but plenty of slots in the case open for use (that's what I meant by single-slot). Pretty soon I'm going to need a graphics upgrade as I'm a semi-serious PC gamer (but not so much that I'll spend the money for a 9800GX2 :kaola: ). So let's assume that my max budget for a single video card is $250 - $300, but even so, try to keep the price low. This card should also run fairly quiet and I don't care about how hot it gets, just so long as it doesn't melt, get artifacts or crash or anything. Passive cooling would be best, I suppose. The monitor I use is fairly old, but runs at a native resolution of 1280x1024, but I do want to play at 1920x1200 with a newer monitor sometimes in the next 6 months. I can also overclock fairly well, but have no knowledge of anything too advanced, such as volt mods, water cooling or installing third party VGA coolers. I also occasionally run Linux and from what I hear Nvidia drivers are easier on it.
So, given all this, what would you say is my best option for an upgrade?
Message edited by mathiasschnell on 03-30-2008 at 07:52:50 AM
Sponsored Links
8800GT 512MB for $175...nothing can beat it in price : performance. 8800GT/GTS performance is about the same as anything that has double the price tag. If you want to spend about $225 or so get a 8800GTS 512 MB, but you won't see any real performance change, just runs a little cooler (basically a 8800GT + aftermaket cooler + 5-7% better performance on higher resolutions). Now if you want to spend about $350....get 8800GT SLI....2x8800GT is amazing performance for $350...beats anything that cost twice as much, just like the 8800GT.
Message edited by qmalik on 03-30-2008 at 08:18:52 AM
Reply to qmalik
I dunno, this is really tempting to me now.
http://www.newegg.com/Product/Prod [...] 6814261002
$120 after rebates for only 10 - 20% worse performance than 8800GT. And given the reviews, it's rather quiet too.
Reply to mathiasschnell
yeah thats pretty nice. That looks to have very nice price : performance ratio.
1 thing though, if you are big on warranty, I don't think that comes with a good one.
So I recommend: 9800GT < 8800GT < 8800GTS. All have great performance for price. ATI 3850 and 3870 are also great, but I personally think NVIDIA has better price : performance ratio right now.
Message edited by qmalik on 03-30-2008 at 08:26:37 AM
Reply to qmalik
If you're getting a new monitor like you mentioned I would say the 8800GTS.
------------------------------ P35-DS3L Rev 2 bios F9C l E8400 @ 3.6Ghz @ 1.232v l OCZ Vendetta 2 /LGA775 Bolt-Thru l 4GB G.Skill 8800PI@1000mhz 4:5 @ 1.87v l WD3200AAKS 320GB l Evga 8800GTS 512 l X-Fi Xtreme Music l Corsair HX520 l Antec Sonata III 500 l Vista32 SP2 l Win7 X64 7600
Reply to kpo6969
6 Months time!
Get the 9600gt for $120 perfect for your setup
Reply to dos1986
Another vote for the 9600GT, would fit your bill perfectly with the resolution you are playing at now.
If you think you may get a new monitor, or maybe pick up a couple of new games in the next 6 months, then I would go the extra $$ and get the 8800GT. The GTS is starting to get too pricey for the performance gain over the GT. Not that big a difference unless you start upping the resolution pretty high. The GTS does have better cooling though.
For pure performance VS $$, almost everyone will tell you that a 8800GT is really powerful card for the money spent.
Message edited by jitpublisher on 03-30-2008 at 04:27:04 PM
Reply to jitpublisher
There are 1285 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
