Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > System won't boot up after getting an aftermarket cooler!
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - System won't boot up after getting an aftermarket cooler!
I've just installed a Tuniq Tower 120 on my E6600/8800GTX/4GBram/500W Asus power supply.
I had to remove motherboard, rebuild stuff etc. Now the system will not boot! I mean all starts spining and stuff bot nothing on the screen. No motherboard beeps either. What is wrong? Is it possible that my 500W Asus could not go with just another aftermarket cooler and it did with the stock one?
* later edit: PROBLEM SOLVED
all I had to do was boot with no ram then put ram back in and it finally did boot.
Thread closed.
Message edited by illusionx on 04-18-2008 at 02:29:35 PM
Sponsored Links
Clear the bios.
Check all connections and screws.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Glad you found a solution.
Reply to evongugg
There are 592 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
