Wow. Those still exist? I haven't heard of them in a while. Lets see.....
Well the MaxOrb will probably fit better as it is a bit smaller but it will rull air from the direction of the fan to the HS. Normally it is best for the ones that lay flat on the desktop and have a vent directly over the HSF.
I have the case Antec Sonata III, so my board is mounted vertically...What I mean will it work vertically is..Because these are push-pin ones..If u keep the system vertical, then push clips may not hold the cooler well (compare to the ones with backplate) since the heatsink maybe too heavy..However if u keep the casing lie flat on the floor than the heatsink weight bear down on the floor.
Can u give me some coolers that u said lay flat on desktop and have vent directly over the HSF? Thanks!
