Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 3870x2 HDMI sound + SupremeFX II = no sound!
Forum Graphic & Displays : Graphics Cards - 3870x2 HDMI sound + SupremeFX II = no sound!
OK people, here is the deal.
I got a Asus Maximus Extreme + 3870x2 + SupremeFX II Sound Card.
Can't get any sound out of it. I've tried uninstalling hdmi drivers, didn't work. tried disabling them, didn't work. Tried uninstalling my 3870x2 drivers, couldn't install any sound drivers.
http://img150.imageshack.us/img150/6702/errorhs3.jpg
I need HELP! :@
Don't know what else to try. Getting pissed off about it. Two days trying no success.... PLEASE HELP ME OUT!!
Message edited by demon1br on 03-30-2008 at 11:50:29 PM
Sponsored Links
Did you make sure that the SupremeFX is the defaoult sound device?
Windows likes to make the HDMI sound the default device.
------------------------------ Maximus Formula | q9550@3.6 | 4 GB Kingston HyperX @1106 5-5-5-15-2t | Zalman 9700 | Silverstone 750 | Sapphire 3870x2 | Visontek 3870 OC | 500 GB Vista 32 OS | 74 GB Raptor RAID0 | 74 GB Raptor RAID1 |Samsung SATA DVD | X-Fi Fatal1ty | Thermaltake Armor
Reply to firebird
No, i didn't. I don't know how. =P
I currently don't have SupremeFx II drivers installed. I can't install them.
Message edited by demon1br on 03-30-2008 at 11:45:44 PM
Reply to demon1br
- 0 +
What happens when you try to install the SupremeFx drivers? Does it say there is no compatible hardware?
To change the default sound (like to integrated so you at least get something) go to Control Panel and to sound and audio devices.
------------------------------ Phenom II X4 940 BE 3.0GHz - 1.25V > GA-MA790GP-DS4H > XFX ATI 4850 1GB > 4GB OCZ Platinum 1066MHz 5-5-5-15-2T > PCP&C 610W
Athlon II X2 250 3.0GHz > GA-MA770T-UD3P > Sapphire ATI 4650 512MB DDR3 > 4GB OCZ Platinum 1600MHz@1066MHz > XP/Win7 Enter 64
Reply to EXT64
- 0 +
Oh, I just looked at the picture and I see it says there are no compatible hardwares. I also see that it is Vista, so my default sound fix probably won't work either. Are you sure the drivers are Vista drivers?
edit: by the way, is that Portuguese? (I'm guessing since you are from Brazil and it looks like it)
Message quoted 1 times
Message edited by EXT64 on 03-30-2008 at 11:57:22 PM
Reply to EXT64
- 0 +
That board has no onboard sound, that's why it comes with a card. If you have it plugged in the second pciex1 slot (white) pull it out and put it into the first pciex1 (black).
Reply to dagger
- 0 +
Oh I see. Does Windows recognize hardware is present in Device Manager (or whatever Vista calls it)?
Reply to EXT64
I can't install any drivers. The picture above says: your audio files are not compatible with your hardware.
This is all i can get at control panel >> sound. http://img144.imageshack.us/img144/2388/error2yt4.jpg
Im sure im using vista32bit drivers.
Yeah, thats portuguese.
There is no black pci-e. I cant see them if they are there. =/
http://c1.neweggimages.com/NeweggI [...] 235-05.jpg
Reply to demon1br
- 0 +
In that picture there is. Is there not one on your board?
Reply to EXT64
- 0 +
http://c1.neweggimages.com/NeweggImage/productimage/13-131-235-05.jpg
See that little black thingy pressed right up against the big heatsink? :p
Reply to dagger
RAAAAAAAAAWWWWWWRRRRRRRRR!!!!
FOUND IT!!!
THX GUYS!!! I'll switch the sound card to the black pci-e and post the results here.
Reply to demon1br
OH GUYS!
Thank you very much!
WORKED NICE!
THANKS THANKS THANKS!
Reply to demon1br
- 0 +
Wow, really? Glad it worked out.
(500 posts, yay!)
Reply to EXT64
- 0 +
Lol, that slot is the only one where the sound card will work. I did some deep research on all x38 boards, because I wanted to buy one.
Reply to dagger
- 0 +
just curious.... how good is that sound card compared to "x-fi fatal1ty professional series"
Reply to imrul
Quote :
Well, since Vista and dx10 have changed the way audio is handled, the X-Fi doesn't work as well as it does in XP. Games must use openAL for sound instead of the direct sound used in direct X in previous versions. So I had to install another Creative app, Alchemy, to provide EAX capability.
If you don't consider EAX a must have, I would not change the SupremeFX for the X-FI. The sound quality improvement is minor.
Another reason I changed was because I have a Creative 7.1 speaker set that only has 3 connectors for sound. The SupremeFX wanted 4 for 7.1. I could only manage 5.1 on my speaker until I got the X-FI
Reply to firebird
- 0 +
damn.... i feel stupid... i had bought x-fi, then later found out that the motherboard i bought the day after came with supremeFX.
Reply to imrul
I don't know what's with the driver for SupremeFX II sound card. What I did was buy a Creative Sound Card and Install the driver first then the computer can be able to detect the sound card otherwise it won't detect any sound card at all if you are not to install the driver first. Works for me
Reply to Anonymous
There are 741 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
