Tom's Hardware Forums » Homebuilt Systems » New System Build » new build blank screen HELP!
Add a reply
 Word :   Username :
Bottom
Author
 Thread : new build blank screen HELP!
Profile: stranger
More Information
ok i got
mobo: MSI P7N SLI Platinum LGA 775 NVIDIA nForce 750i SLI
video card :7600gt ko upgrading soon
psu: FSP Group FX600-GLN V2.2/EPS12V 600W Power Supply
cpu:Intel Core 2 Duo E6750 Conroe 2.66GHz LGA 775
hardrive : segate sata
cd drive : some dvd/cd burning
ram: G.SKILL 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
cpu cooler : artic cooler 7
case : xion onyx
well basically everything sounds to be working case fans cpu fan videocard fan lights red led on mobo videocard and monitor do work im using them right now i been basically been trying to get my new comp working for 1 and half days i hope some can help me o and i connect the mobo speaker but hear no beeps so idk how i can fix my problem plz help some one
Related Pr oduct
Profile: stranger
More Information
can anyone help me plz
Profile: stranger
More Information
any1?
kad
Profile: addict
More Information
What is the problm ??
You are saying everything is working !!!
Profile: stranger
More Information
but i dont get a display on the screen so i cant install or do anything its just sits there like the computer is off
I'm an atheist,,thank god...
Profile: enthusiast
More Information
EJ101 wrote :
ok i got
case : xion onyx
doncha just hate it after all the waiting and pffft,,now then,,are you absolutely certain that all your power and data cables/ribbons are firmly connected,,???motherboard properly mounted and suchlike,,if everything is so ,,,then,,,you are going to have to remove it all from the case and setup out side said case,,,with just the basics ,,ie,ram,and video and a floppy, as i have said before when you or i get a snafu we have to go back to basics,that is the only procedure for checking out the faults either yours or your installation,,it seems that all your hardware is new?? so we are forced to conclude that there is an installation fault,the fact that you are not getting a bios beep is suggestive of some kind of hardware failure/bad connection,one little thing did you connect the 4pin 12volt connector to the mobo,goes near the cpu??:)
Profile: old hand
More Information
What have you already tried, to get it working?  I would suggest checking everything, and try disconnecting everything, but the ram, PSU, GPU, CPU with heat sink, and monitor, and see what happens.  If nothing, then take the mobo out and put on cardboard, and try again with the same set up and see if there is a change.
Profile: stranger
More Information
thanks for your guys repplys i think i connected all the wires this is my first build so i dont know everything and by the 4pin 12 volt do you mean the cpu fan and i got a 8 pin 12 volt by the cpu. and i try taking it out and putting it on the mobo box whic is cardboard im thinking the mobo is doa but red light on indicates its getting power and im not to sure of all the plugs i bet there a little plug i forgot but i cant figure it out and ya all my parts are new except hardrive and cd drive and video card
Profile: stranger
More Information
Is there a way you can post a side shot pic of ur PC without the panel? Would maybe help us figure out the problem.
Profile: stranger
More Information
i have these 2  i can also take pick of mobo out side of case
http://i28.tinypic.com/343q989.jpg
http://i29.tinypic.com/b5pnup.jpg
Profile: stranger
More Information
Profile: stranger
More Information
I'm guessing ur rams are 1 x 2gig right? If so they are connected properly. Like Dokk said don't forget to plug the 12V connector near the CPU. I don't know if you have a another video card you could try but id check that next. Also make sure ur PSU switch in the back is at 115V.
Profile: stranger
More Information
ya 1 2gb gskill ram  and my psu dont have that voltage switch and also i dont have another pci-e card i dont have no beeps or anything so i cant do that omg im getting frustrated =/
Profile: stranger
More Information
i think i know the problem i have to do something with the jumpers but i cant find anything in my manual about it unless its a high tech word in manual
Profile: stranger
More Information
im thinking its my cpu intel core duo 2 e6750 i cant test it cuz i dont have another computer that has socket 775 is there any way to check?
Profile: stranger
More Information
i dont even have jumpers or i have to add them man idk
Message edited by EJ101 on 03-22-2008 at 07:42:38 AM
Profile: old hand
More Information
OK EJ101, take a deep breath.  OK first most motherboards come with there jumpers, so check the packaging.  Check and see if there is anything on reseting the BIOS or CMOS in your manual, that's usually were using at least one jumper comes in.  Second take the mobo out of the case and put it on cardboard, and just connect what's need for a barebones test (PSU, GPU, CPU, RAM, and monitor), this will help you narrow down the possible problems, and let you get a better look at the motherboard and it's connections.
Profile: stranger
More Information
ok im going to try later when i come back thanks for the advice.
Profile: stranger
More Information
does it matter how i start it and if i dont see anything on screen while its out of case does that mean my stuff is broken
Profile: stranger
More Information
someone told me to plug in the aux power plug but idk i my mobo has that.
Profile: old hand
More Information
Make sure the power is connected properly by the manual.  You can usually start the mobo out in the open by crossing the two pins, for the power button, with a screw driver or pin.  If you don't see anything on the display with it out like that, with just what's needed to test with then, something there isn't working like it should.
Profile: stranger
More Information
i might bring it to a professional but i want to learn my self and dont want to pay but i guess i have no choice.
Run..Run.Hide.
Profile: old hand
More Information
