News
IBM promises cooler chips with capillary-action and water jets
Published on October 27, 2006
IBM's Zurich labs have developed a new heatsink and water-cooling that promises to cool chips up to six times better than conventional air cooling. The heatsink contains tiny channels similar to the capillaries you would see in tree leaves and in human circulator systems. The channels allow either water or heatsink compound to spread more uniformly and thereby dissipate more heat. Read more
Thermalright Ultra-120 Copper Hitting Shelves This Month
Published on October 15, 2008
The highly popular Thermalright Ultra-120 Extreme will soon have a new heavyweight counterpart. Expreview have received notification that a copper version of the enthusiast CPU cooler will be available this month for a price of $100-110... Read more
Heatsink Maker Jumps Into LED Lighting Biz
Published on August 22, 2008
San Francisco (CA) - Taiwanese heatsink maker, AVC, is jumping into the drop-in LED lighting market with its multiple LED lighting heads. Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Latest Reviews & Articles
Tom's Holiday Buyer's Guide 2008, Part 1
Published on November 05, 2008
Welcome to the first installment in our six-part Tom's Holiday Buyer's Guide. In Part 1, two beautiful models help showcase some of our favorite no-hassle hardware gifts for 2008. Read more
Round Up: Five Powerful, Light Ultraportables
Executives, road warriors, and gadget geeks all lust after ultraportable notebooks. Five of these amazing machines battle it out in this roundup. Read more
Core i7: 4-Way CrossFire, 3-way SLI, Paradise?
Published on November 04, 2008
For the first time ever, gamers are being treated to a reasonably priced platform enabling the best that AMD and Nvidia have to offer. Is Core i7 a gamer’s nirvana or does the processor serve up more of the same? Read more
Editor's Corner: Overclocking Core i7
After discovering Intel's Overspeed Protection in yesterday's first-look at Core i7's performance, we're back to set the record straight on the overclocking headroom of the flagship 965 Extreme and entry-level Core i7 920. Read more
Heatsink Problem!
Word :   Username :
Bottom
Author
 Thread : Heatsink Problem!
Profile: newbie
More Information
Okay. I need help. I need to buy a new heatsink, and this is the one I've chosen: http://www.alpchat.com/images/scythe-katana-2-1.jpg
It's socket 478, as is my motherboard. Problem is, I don't know if it will fit.
This is my computer: http://img257.imageshack.us/img257 [...] 957jf3.jpg
I want to replace the current heatsink with the Scythe Katana 2. The current heatsink is like 8 cm (length.) The new one is at least 10.5 cm in length. However, the scythe katana is mounted at a 90 degree angle, unlike most tower heatsinks.
Will the battery looking things on the motherboard get in the way?
Related Product
Profile: Forum Fixture
More Information
It'll fit, don't worry. That's why the body is raised and connected with heatpipes, for ground clearance. And side mounted fans are the norm with aftermarket coolers. They perform better.
Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Profile: Honorary Poster
More Information
The battery looking things are capacitors and no it should be fine. You should be able to mount the Scythe with the fan facing either the back or top depending on clearance, toward the back being better if you have a back fan which I don't see. Your goal should be to face the fans air flow toward the nearest fan that can remove the air from the case.
http://i192.photobucket.com/albums/z311/AUsch30/badge_wtp_02_3001.jpg
It is the mark of an educated mind to be able to entertain a thought without accepting it.
-Aristotle
Profile: newbie
More Information
Thanks for the quick reply. I'll buy the fan and try to put it in. Besides the heatsink and my power supply fan, I have no other fans. No case fans. So, if it isn't too much to ask, where exactly should I make the Scythe face?
Here's a picture of my entire computer- http://img403.imageshack.us/img403 [...] 657sf1.jpg
I'm not going to buy any case fans yet, so should I just make it face the back (to the left in the picture) where the ventilation holes are?
Thanks.
More Information
Thanks.
Face the back, meaning the side with the fan facing the front so that it expells hot air to the back. And you should really get at least one case fan. They cost like $3-5 each.
More Information
-Aristotle
Google Ads
