Dual Monitor Help
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Dual Monitor Help
Profile: journeyman
More Information
Hey - As you can see I am running dual monitors on my pc but I need some help
Every time I boot up, I have to reset the resolution on one and move it's placement
And ideas on how to make windows remember the settings for the second monitor??
Here's what I want it to be
Main = Right side @1280x1024
Secondary = Left Side @1024x768
And it boots like so
Main = Left side @1280x1024
Secondary = right side@1280x1024
Thanks
And I hope this is the right place for this question
Athlon X2 6400 @3.2ghz
2gb DDR2 533mhz
nVidia 8500GT 512mb
250gb Sata
Related Pr oduct
Profile: journeyman
More Information
bump
2gb DDR2 533mhz
nVidia 8500GT 512mb
250gb Sata
Profile: newbie
More Information
hey there buddy, ok.  first off, what kinda vid card do you have?
ATI or Nvidia.
I have a dual monitor setup, and this is what i have
Dell 22'' widescreen (main)
LG 19'' (Secondary)
I have an Nvidia 8800 GTS 640 mb card
now.  I connected my 22'' first, set it up the way of the resolution i want.
then i shut down
then as its shut down, i connected my LG
turned the computer on, and went into my nvidia control panel
i had the control panel set them as individual monitors.
and yes you can set them to the resolutions you want.
and then when im done, i restarted.  and as you said your main turns on first, then my 2nd
hope that helps.. with ATI i dont have an ATI card, but im sure if someone does, they can help you set up the dual monitor.
Profile: journeyman
More Information
thanks alot - I have an 8500GT
2gb DDR2 533mhz
nVidia 8500GT 512mb
250gb Sata
Add a reply
Google Ads
