I have been given a dell 110L Latitude, i wanted to re-format the laptop.... but then found out that the d-drive is missing, i couldnt find it anywhere on the laptop, even after putting a disc in, the light would come on, but wouldnt load.
So i followed someone elses advice on the forum, where i had to go to the REGEDIT... and delete upper and lower filters, then restart, then the d-drive should appear.
I done this and now when i start up, i get an error message....missing - windows root system32 hal.
And when i go into the bios, it is saying that there is no hardrive.
Hellllppppp, i havent got a clue why this is happening.
Thanks for answering so quick.... but thing is, i cant re-install the drive's, as i cant go any further than either seeing the message (As above) or getting into the bios.
