when i set my os to boot from a cd then insert the xp install disk it starts loading the driver files before it gets to the formatting stage. before it gets to the formatting screen the computer just goes idle with a blank screen, and no RAM,HD, or optical drive activity. I tried a knoppix cd and after i select boot it just goes idle as well, but i can use the knoppix cd to do a memory test which will run for hours without overheating so that isn't a problem.
This pc has worked fine for nearly 3 years then just crashed one day while idle in windows. Iv'e gone through the basic troubleshooting steps and thought it was the mobo so had that RMA'd but it hasn't helped. I'm guessing either the power supply or processor?
