Tom's Hardware Forums » Homebuilt Systems » General Homebuilt » Upgrading Components - need help
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Upgrading Components - need help
Profile: stranger
More Information
Well, today i've decided that i'd like some faster speeds off of my computer. My original home built specs are:
18               1   MSI RS482M4-ILD Motherboard - 939 Pin
19           1  AMD Athlon 64 X2 Dual Core 4600+ 2.4Ghz
20           1  2 GB DDR 400 SDRAM, 2 x 1 GB
21           1  1.44 MB Floppy Drive - Black
22           4  500 GB 7200 SATA Hard Drive
23           1  16X Dual Layer DVDRW Drive
24           1  ATI Radeon X800XL 256 MB PCI-X Video
25           1  Integrated 8-Channel Audio
26           1  Integrated 10/100 Ethernet
27           1  Logitech PS/2 Keyboard + Optical Mouse
28           1  XPP SP2 Operating System
29           1  Linksys Wireless-G PCI Adapter
30           1  Midtower Case - 450 Watt - Black/Silver
This build is nearly 2 years old.
I've already bought a few components - 8800gts(256mb) 2 more 500gb hdd's
I fear that i may be maxing my PSU also.
I plan to add a new cpu- and rehaul the mobo.
http://www.pricepoint.com.au/shop/ [...] s_id=15756
http://www.pricepoint.com.au/shop/ [...] s_id=11849
This is my toss-up, I am looking for a high performance gaming computer, but it must also work well with multitasking(vid editing, 3d modeling, etc...)
I am unsure of a motherboard as of now, but i am leaning towards:
http://www.newegg.com/product/prod [...] 6813131235
OR
http://www.i-tech.com.au/items.aspx?id=25077
I'd like your opinion on what i've chosen, and what needs changing etc...
I'm not looking to spend more then 600AUD
Thanks,
Blake.
Related Pr oduct
Profile: Eternal Poster
More Information
Quad is still the better choice for video editing & 3D modeling as long as the software makes use of the cores. The CPU prices converted to USD are $270 & $335. There's a $65 difference. In North America, the Q6600 sells for about the same as the one in your country. That's regular price. However, the E8400 is gouged to ~$250, to be dropped back to $220-ish.
In a nutshell, go with G0. No jokes. Q6600 stepping G0 or B3.
If you plan to keep the pc for a year or longer, go with a premium X38/X48 motherboard like ASUS MAXIMUS FORMULA, P5E, etc. If you plan to upgrade to Nelahem, pick up a budget P35 board like DS3L/P5K.
Throw in any 2X1GB DDR2 800MHZ ram deal.
Message edited by akhilles on 03-24-2008 at 01:14:22 PM
e8400@4ghz | Coolit Freezone | LP UT ICFX3200-T2R/G | HR-05-SLI | Ballistix PC2-6400 4x1GB | HD 4850 | HD753LJ | GSA-H62N | EGA1000EWL | RC-690-KKN1-GP | Vista 32 | W/V=A
Profile: addict
More Information
from reading these forums, It looks like intel base mobos don't OC as well as nvidia based mobos.
you may be able to reuse your PSU with the E8400. The q6600 draws more power, so its less likle to work propperly. either way, your on the edge. sometime cheap PSUs fail catostoficaly and take other components with them. I'd upgrade the PSU and get a cheaper MoBo myself.
If your considering SLI (what is your screen resolution?). definatly upgrade the PSU.
For me, there isn't enough improvement going from you dual core to another dual core (but I'm cheap). if you'd actualy use all 4 cores, get the quad.
Profile: stranger
More Information
As much as i'd like to nod and pretend to know what has been recommended, i'll ask quite frankly. What does "In a nutshell, go with G0. No jokes. Q6600 stepping G0 or B3." imply?/mean? ;p
Profile: enthusiast
More Information
@groo - Intel based mobos generally overclock better than nvidia based mobos.
G0 is the latest stepping for the Q6600.  It uses slightly less power and has better thermals than the previous B3 stepping meaning it will generally overclock a bit better.
Go with DDR2 ram not DDR3.  Based on your motherboard choices it looks like you're considering DDR3 but I wouldn't use that right now.  It's too expensive for very little benefit.  I'd grab a 2x2gb kit of DDR2 800 to go with the upgrade.
You tell me what I do.
Profile: Faithful Poster
More Information
how can you get a 8800gts in 256mb?there is only 320/512/640.
do you mean 8800GT or 8600gt or 8600gts in 256mb?
THIS IS SPARTAAAA!!!!!!
Profile: stranger
More Information
unless your os is 64bit id suggest you dont even bother with 4 gigs of ram, since you wont be able to utilize it all.
More Information
What uguv said.
After you pick up G0, hard mod the vcore, vdimm, vfsb, vmch, etc. :D :D :D :D j/k
Intel chipsets overclocks better than nvidia's. Google for yourself.
Add a reply
Google Ads
