Tom's Hardware Forums » Homebuilt Systems » New System Build » New build. Please double check my work for me. :)
Add a reply
 Word :   Username :
Bottom
Author
 Thread : New build. Please double check my work for me. :)
Profile: stranger
More Information
I'm helping a friend put a speedy stock system together.  He won't be overclocking.  Are there any glaring mistakes here or should this all go together fine?  Thanks for your comments.
Thermaltake armor case    http://www.newegg.com/Product/Prod [...] 6811133154
Gigabyte GA-P35-DS3L  P35 mobo     http://www.newegg.com/Product/Prod [...] 6813128059
Antec Earthwatts 500 Watt PSU    http://www.newegg.com/Product/Prod [...] 6817371007
Intel E8400 Retail       http://www.newegg.com/Product/Prod [...] 6819115037
Corair 2x 2GB 1066 DDR2  (TWIN2X4096-8500C5DF)    http://www.newegg.com/Product/Prod [...] 6820145197
PNY XLR8 9800 GX2 1GB   http://www.newegg.com/Product/Prod [...] bgx2%2bpny
Creative Soundblaster X-Fi Xtremegamer    http://www.newegg.com/Product/Prod [...] 6829102006
WD Raptor 150gb SATA     http://www.newegg.com/Product/Prod [...] 6822136012
WD Caviar SE 250GB SATA    http://www.newegg.com/Product/Prod [...] 6822136161
Related Pr oduct
Profile: stranger
More Information
I am working on building my first custom PC and came across this question and maybe you can give me your thoughts.  I am using a Gigabyte mobo as well and I didn't see the need for an additional sound card given that most (including the new Gigabyte ones) have pretty good supported sound right on the mobo.  The mobo you chose has 8 channels with the Realtek chipset for audio.  Couldn't you just save the 90$ you were planning on spending on the audio card, or better yet use it towards a bigger monitor or higher end speakers?  Im just curious what your thoughts are on this.  Also, why are you using multiple HDDs?  Are you planning on having the system auto back itself up as it goes?  I just think you could get a 500GB HDD cheaper than the two hard drives together.  Also, you are aware that if you are using a 32 bit OS (whihc you should) that the system is only going to recognize about 3 Gigs of the RAM you are buying.  Have you built a system before?  Sorry if any of my question or inquisitions are bothersome, but since I will be doing this soon, its nice to get dialogue going with someone else who is doing this.  What do you have the whole system priced out at?  What type of monitor is he going to buy?
Profile: stranger
More Information
Also, do you have a DVD drive picked out?  Would hate to see you about to build everything and then realize you forgot the CD drive.
Profile: enthusiast
More Information
That has happened by me long time ago, then I have no Idea how can I install the OS....hehehehehe....Come to think about it, I was stupid...right?
Intel Q6600 + ASUS P5E X38 +
4GB DDR2 1000 CL5 Mushkin + Coolermaster Dominator Xcalade 690 + Corsair VX 450W + HIS HD 3850 512MB Turbo + Seagate 500GB 7200rpm 32MB + Zalman CNPS 9700 LED + Logitec EX110 + ASUS VW198S.
Profile: stranger
More Information
The x-fi is just a preference, and only $50 after rebate.  We're using multiple HDs becasue the Raptor gives the best gaming performance but is only 150GB.  The WD SE 250GB is for mass storage of media, etc.  Ram is so incredibly cheap right now that It's worth it IMHO to buy 4GB and get 3GB.  DvD drive is leftover part from another system.  Monitor tbd.  Total system cost after rebates and shipping was approx $1600, not counting the dvd drive, monitor, or speakers.
Profile: Forum Veteran
More Information
You can save $30 with this RAM:
Crucial Ballistix 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
http://www.newegg.com/Product/Prod [...] stix%2b4GB
I would pay $10 or $20 more to get the BFG or XFX version instead of PNY.
The PSU is under the 580W minimum recommendation. You're also adding Raptors and soundcards there, it's not even a minimal system any more. For a system with a $600 video card it's worth buying a decent PSU. Here's a good one, with the 6/8 pin connectors and the amps you need:
PC Power & Cooling Silencer 750 Quad (Crossfire Edition)
http://www.newegg.com/Product/Prod [...] bCrossfire
The 750GB WD7500AAKS is faster than the 250GB disk you picked, and quite comparable with the Raptor 150GB in most benchmarks. It's also cheaper per GB than either of them.
Add a reply
Google Ads
