Tom's Hardware Forums » Homebuilt Systems » New System Build » HELP!!!NEVER ATTEMPTED SYSTEM!!!
Add a reply
 Word :   Username :
Bottom
Author
 Thread : HELP!!!NEVER ATTEMPTED SYSTEM!!!
You tell me what I do.
Profile: Faithful Poster
More Information
http://45qzlg.bay.livefilestore.com/y1pedVwQhARuXGEvG33bgZv1oX4Y0lukFztzYELAiHAodwnkvTJlPDRWZe1WZZhhSNVOEGPGdh8P-oN30ktIxpcEw/spec.JPG
what do you think of this build?i have never build a amd system in my life!!!is this one thats got hdmi out on the motherboard?
purpose?cheap home run pc for very basic general use.
Related Pr oduct
Profile: addict
More Information
Should do well, but keep in mind that the on-board video will eat into your system ram.  Also, if you want to run the ram at the rated speeds, you'll need to change the muliplier to an even number.  Easy to do with a "black box" edition because of the unlocked multiplier, but not as good on the non-"black box" edition becuase with the non BB you'd have to lower the multi.  If you had the BB edition you could just up it to 14 vs the stock 13.   Its a memory divider thing.  If this is your first AMD, then you wouldn't know that.  Another way to increase the speed of the ram is to just up the system clock until it takes you to ~ 400 MHz (DDR2 800 spec).
More Information
yeah tis is my first amd build.isnt the black box people say just normal amd but only got a unlock multiplier?the rest is the same cache etc.
Profile: addict
More Information
Yes, the unlocked multi is the only positive.  Don't get the unlocked 6400.  3.2 is about as high as it would go anyways. You wouldn't want to increase the multi from 16.  If you wanted to squeez more out of it, you'd just up the system bus... but you wouldn't get that far anyways.
More Information
so would you say the BE 5000 can oc to 3.2 like the 6400?
Profile: addict
More Information
No one can guarentee an OC.  http://www.newegg.com/Product/Prod [...] 6819103194
85 bucks.  I can't find an OEM 5000 on egg.  At least not at first sight.  What was the cost of the OEM chip?
Profile: addict
More Information
Thought... I'm not familiar with that cooler.  Is it good?  How much for it?
More Information
that is the 2nd gen of hyper tx.the one tom's used for its low cost system.
Profile: addict
More Information
How much is it?  I like the zalman 9700.  The AM2 install really isn't that bad for the 9700.  The 775 install is another story.  The zalman website is better then the instructions that come with it though.
More Information
its less than £10 only £9.39 and its very good pric/performance.google it and you will see
Profile: addict
More Information
Fair enough.  Go for it then.
Add a reply
Google Ads
