Tom's Hardware Forums » Homebuilt Systems » General Homebuilt » Using an old PC case and power supply as a HDD Enclosure?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Using an old PC case and power supply as a HDD Enclosure?
Profile: newbie
More Information
I was looking at external hard drive enclosures and realized they are kind of very expensive. I have some old computer cases and power supplies at my house so I was wondering if it was possible to just us an old case, an old power supply, some extra fans, and get some eSATA brackets and cables and cobble together an external enclosure for use with my PS3 and PC that I'll eventually build. Or do enclosures require a motherboard and some form of processing to work?
Related Pr oduct
Profile: member
More Information
How do you plan on connecting these HDDs to the PS3?  It only has USB ports, which can't connect to any stand alone drives with only "an old PC case and power supply".
Do what I did.....
http://www.newegg.com/Product/Prod [...] 6817145027
I can be used with USB 2.0 (like on the PS3), or e-sata (on newer computers/mobos).  You can use both IDE or SATA drives with it as well.
Profile: newbie
More Information
In theory I'd use an eSATA to SATA cable and connect to hard drive bay of the PS3. I don't think a USB only HDD can be used to store downloaded games and installed game files.
Profile: enthusiast
More Information
A USB hard drive can be used to store & install game files.
Profile: enthusiast
More Information
As long as you get power to the hard drive, any case would work.
I might be wrong about USB hard drive, but it should work.
Profile: newbie
More Information
I'm of the understanding that a PC Powersupply won't turn on unless it's hooked up to a mobo usually. So I'll have to jump two of the connectors to get it to work won't I?
What's the best way to do this?
Profile: member
More Information
You can do it the low tech or the hi tech way.
Low tech: Get a paper clip and find the 24 pin connector of your PSU. Stick one end of the paperclip into the pin that connects to the green wire (the only green wire outta all the wires) and put the other end in the pin that connects to the black wire directly next to the green wire pin. If you did it correctly you should be able to turn on the PSU (just check and see if the fan starts moving). http://www.dvhardware.net/modules. [...] le&artid=5
Hi-Tech: Pull out and open up your PSU. Take off the casing and separate the molex wires from the 24pin connector wires. Again, find the green wire and the black one next to it. Snip off the green and black wires, and solder them together. You can then snip off all the other 24pin wires. If you do it this way, be sure to wrap the soldered wires in tape or shrink wrap so that it doesn't short out your PSU. http://modfatha.com/building-a-tes [...] ply-2.html
I'd also suggest that you use a PSU with an on/off switch so that you can manually turn on and off your new modded HDD enclosure. If you wanna get really fancy you could always try to reroute wires from your PSU to the front power button of your case so that it works to turn on and off your HDDs.
Core 2 Duo e6750 | Thermaltake CL-P0144 | Gigabyte GA-P35-DS3L |  640MB EVGA 8800 GTS | 4GB Patriot Extreme Performance DDR2 800 | Seagate Barracuda 7200.10 HDD | OCZ GameXStream 600W PSU | LITE-ON DVD-R | Samsung 226BW 22' | Vista 64bit Home Premium
Profile: newbie
More Information
Thanks. I'd like to try and tie into the on off button on the front, but I'm not really sure how that would work. I'll probably just do the paperclip trick for a while. Course all this is still a ways off.
Profile: journeyman
More Information
or, you could just leave the old motherboard in there for the psu to plug into.  not like it's going to draw much power just sitting there with no video or data moving across it!
Profile: newbie
More Information
Wait, will that work? I do have a couple random mobos laying around would putting one if those in there with no processor, video card, or anything?
Profile: addict
More Information
i think you would still need a cpu and one stick of ram, you will get error beeps without a vid card, not sure if the beeps stop after a minute or not.
Q6600 G0 @3.6 1.34v | HD3870X2 1GB | 24" Westinghouse L2410NM| 19" 1907FP | Asus Maximus Formula X38 (Rampage Mod) | Kandalf VD4000 LCS | Ultra X2 750W | Supreme FXII 8.1 | Audio FX Pro 5.1 Headset | 4x1024 Ballistix Tracer 5-5-5-14 1066mhz
Profile: addict
More Information
That's what old PC's are for.....when you build a new one, don't bother trying to cannibalize old parts which will only slow down your new builds....just leave the old box on the network, add the new one and built in backup machine.  There's another thread where someone is getting all new parts but the case....to my mind the $100-$200 "savings" just isn't worth it compared to a otherwise free backup box.
Profile: journeyman
More Information
There are a couple of other alternatives,
Use a PSU tester to fire up the ATX PSU or buy an old AT psu.
Profile: newbie
More Information
I have enough spare stuff floating around in my basement to almost put together another Athlon 2600 system. I've got a spare processor, 3 spare cases, 2 spare motherboards, heatsink(s), like 7 or 8 spare case fans, extra Arctic Silver 3, and some other stuff. I'd still have to buy some DDR Ram, and an AGP graphics card.
The thing is there'd be no real use for it. When I do eventually Build my new system (which will use one of the spare cases), that would leave my with 3 systems, one of while I'd have no use for other than the fact that I've crammed Sata drives into it for my PS3 and future computer.
Profile: member
More Information
Ragnorok - I would imagine that you could get your front power button to turn on the PSU with very little work. Personally I really like the idea of your external HDD bay tower, just because it isn't done and would be fun to do.
Just off the top of my head (I haven't tried this, so don't bank on it working) but I would imagine you could easily route the power to the power button on the front.
1) Extend the wires from your power button to the PSU
2) Attach the power button wires to bridge the green-to-black connection, so that when the power button is on the PSU fires up (ie. green->power button->black)
3) Just leave the PSU switched on and then the power button will act as the on/off switch
Like JackNaylor said, you're not going to be saving money or value by taking the old PSU and putting it into a new system. So you might as well use it for what you want and make a fun mod out of it.
I would suggest that you invest in two molex powered case fans though, to at least get some air moving through the case. It would also give you a chance to test your PSU mod without the risk of frying your HDDs.
My ass does all my talking!
Profile: nimble knuckle
More Information
If you've parts like that laying around, then put together a basic machine, load up Openfiler, and make a nice little NAS. You can then store and house whatever files you want and it will be accessible to all computers on the network including the PS3.
Candy asked me if she died if I could go on
Of course I said I couldn't and of course we knew that's wrong
But Candy I said Candy no you can't do that to me
Because you love me way to much for you to ever leave
Profile: member
More Information
A thought that comes to mind.
If you could get your hands on a few sticks of cheap DDR memory, you could build those 2/3 systems on the cheap and then sell them off on Craigslist for 100-150 bucks. You'd free up some space, get rid of parts you'll never have need for and make 200-300 bucks to pay for your new rig. Well, a new graphics car at least :D
Profile: newbie
More Information
I think I'd end up having to upgrade to a motherboard that could handle SATA. Unfortunately the ones I have are still IDE boards.
Profile: Honorary Poster
More Information
It will cost you alot more money when you burn your house down with some cobled up crap, then it would to buy a HDD enclosure. Just download on the computer then plug into PS3 via usb and transfer your downlods to your PS3 HDD.
Profile: newbie
More Information
Doesn't that kind of sentiment run counter to the spirit of the homebuilt system forum?
More Information
My idea of home built dont include paperclips.
Profile: newbie
