Tom's Hardware Forums » Homebuilt Systems » New System Build » System Builder Marathon: Mid-Cost System
Add a reply
 Word :   Username :
Bottom
Author
 Thread : System Builder Marathon: Mid-Cost System
muk
Profile: member
More Information
We double the budget of yesterday's low-cost PC's and build the best possible PC we can for under $2000.
http://www.tomshardware.com/2008/0 [...] index.html
Related Pr oduct
Profile: addict
More Information
I know three categories keeps it nice and clean, but there really need to be four:
1) low (average around $500, maybe $600)
2) mid (average from $1200 to $1500)
3) high (average maybe a little over $2000)
4) no limit; best parts you care to buy
$2000 just seems really high for mid-range if you're thinking in terms of the average consumer.
Athlon X2 6400+
Gigabyte GA-M51GM-S2G
1 gig Patriot/1 gig Kingston
EVGA 8800 GTS 320
A woman's just a woman, but a good cigar's a smoke
Profile: stranger
More Information
I agree; $2000 is NOT a mid-range system.  When I think midrange, I think $1200-$1500.  I like this catagory for a mid-range system because it's arguably close to the cost of purchasing a console and a good HDTV.  In my position, I'm looking to replace my three-four year old computer (socket 939 and AGP video card mobo so I need to do a complete rebuild) and I'm torn between spending $1200-$1500 (this includes monitor, something THG doesn't include and should) to either rebuild my computer or get a console and good HDTV.  In my mind, a gamer considering a mid-range computer is also the type of person who might consider the console and HDTV gaming solution.  Someone willing to spend $2000 on a new computer (without the monitor which will need to be $400-$500 at least to justify the $2000 tower) is not thinking this is "mid-range"; that is an enthusiest's build.  Mid-range is someone who wants a solid-performing gaming system but doesn't quite qualify as hardcore gamer.
Profile: journeyman
More Information
I don't think the CPU selected is optimal. The editors are spending an additional 240 dollars for 266MGHZ WTF?? The 240 dollars would have been better spent on two additional 500GB hard drive and put the three 500gig drives in a Raid5 array, a much better use of the money. That would provide an effective 1TB of storage and data protection of up to 1 drive failure, much better than an extra 266mghz.
Profile: enthusiast
More Information
Their budgets were talked a lot about in the previous "low range" article's thread and I think/hope they're going to do things very differently next time - $2,000 before a monitor and OS is definately NOT midrange! I strongly think appropriate sized/resolution monitors should be included. I can live w/o the OS being included.
I'd rather the article be delayed a little so that the proper parts could be gathered, ie the SLI 9600's. And they talk about spending twice as much on the Q6700 for such a minor gain....and then go ahead and use it anyway...lol?  Frustrating to read/comprehend O_o
Profile: Forum Master
More Information
You know what? You're absolutely right.
Our SBM focus this time around was trying to fit in the most powerful hardware up to a certain price point; instead of strictly picking the greatest components regardless of price, we picked the most powerful components we could fit in the budget.
We went with the Q6700 because we had space in the budget, but really a Q6600 is a better value choice. We mentioned that in the article, but the feedback we've been getting is that our readers would prefer us to have selected value over price point.
What I can say is that the editors are taking the feedback into account so we can change it to suit our readers' expectation next time around. In the interim, keep in mind this SBM might not fit your expectation unless you're aware our goal was fitting the most powerful hardware you can under $2000.
We hear you and appreciate your feedback. By the sounds of it, you folks will find the next SBM much more satisfying!
Message quoted 2 times
Message edited by cleeve on 03-25-2008 at 08:21:21 PM
Core2 E6750 @3.68 Ghz
(on Asus P5K)
Wintec DDR2-800 2 GB
Geforce 8800 GTX and Radeon 2900 XT
Samsung 245BW 24" LCD
Profile: addict
More Information
This got me upset. :(
Gigabyte GA-P35-DS3L*Intel E2180 OC 3.00Ghz Lapped*PowerColor ATI 3850 256MB*Patriot 2x1GB DDR2 800*Cooler Master CM690*Western Digital 250 GB*Silverstone Strider 600 Watt Modular PSU*Samsung Lightscribe Drive*CoolerMaster Geminni II Lapped Mirror Finish
Profile: stranger
More Information
I think it was quite an odd choice as you can buy the new yorkfield q9300 2.5 GHZ for about $300usd. Or maybe even the Q9450 2.66GHZ for $399usd. It seems to me that if you can get a newer core cpu with the same clock for cheaper you should do so.
Profile: journeyman
More Information
indeed, the q6700 was a bad choice for the budget... for those extra dollars you could have bought a better case (if needed) and a better CPU cooler: Tuniq Tower as example.
I don't think I have a midrange gaming system cause seriously. I've spent 1400 US on parts. to put this together.
Q6600 G0 stepping, @ 3,2 ghz 400FSB 1:1 ratio
2 gigs Corsair XMS2DHX DDR2 800mhz 5-5-5-12 1,9v
EVGA GF 8800GTS 512 OC'd and silent @ 720 core and 2000 mem.
Raptor 150 gb 10.000rpm
sata2 Samsung spintpoint T166 500gb.
Thermaltake armor case
OCZ GameXsteam 700Watt PS.
Abit IP35 Pro "Off limits" mobo.
Is that considered midrange? i thought it was high-end pretty much. It's a good bang for the buck. Except for some parts. But why not OC the q6600 a little more instead of using the Q6700.
I hope this helps a bit, I love your articles. But sometimes they are just plain confusing. Maybe it's also difference of tastes.
notice: you could also have put 2 raptors in raid 0 for that cost.
notice2: don't spare out on a cpu cooler, with that case a Tuniq will easily fit in.
notice3: haven't heard much from that mobo, but it seems a good choice.
Profile: member
More Information
Any chance we could get a comparison with the last marathons systems and a check of how much it would cost to upgrade them to simular performance?
It's the little things that do the big difference!
Sniper
Profile: Forum Veteran
More Information
I understand the point of the Q6700. Next time I thing they should call a Mid cost system at $1500 a high end at $2600 and a really high end at $3500+. Great choice on the RAM, PSU, Case, and motherboard (Although I would prefer a Gigabyte EX38-DS4 ~$206). All the mentioned are solid choices. The CPU cooler is not to my liking, would have preferred a good Zalman or a Thermaltake (ie. Zalman CPNS 9x00). The Raptor seems kind of useless giving the fact that 7200.11 HDDs are only few milliseconds slower in most things, and has better value per GB and price vs performance.  radium69 has a good system listed above.
E2180 @3.2Ghz + P35DS3L +8400GS (700/475 OC)
http://farm4.static.flickr.com/3268/2588429538_b3c41b29c3.jpg
Don't merely exist; live.
Profile: Honorary Poster
More Information
Here is how I see it, for what it's worth:
forgetting price at all... if you place all available procs on a chart based on performance (dual sockets included), the Q6600 is not at the top. It is at a higher point of the middle, sure... but not in the top bracket.
Same goes for the gts, while there are less positions on that chart than for CPUs the same is true, it is still bested by a gtx, gx2 and many dual/tri/quad card setups. Still high-middle but not the top. The rest of the components have less of an impact but the same holds true there.
You cannot base a performance range on price and vice-versa. It is either performance bracketing or price and ranked on the same. If you consider that their brackets for low/mid/high were (I assume here) based on performance first, then it all becomes clear IMO.[:mousemonkey:2]
If you are basing it on price and put the same scale at work with all possible price points of a computer system in scope then you find that instead of the upper-middle yours is now very much in the lower brackets of the range.
This is not a reflection on you or your parts choices but rather the cold reality that the top end stuff is expensive. Always has been. Most of us have a level that we build to and it usually is in the mid-range area even though it may be "high-end" performance to us. My last build was 2 years ago and cost me $1500 (no monitor or peripherals in that) and I had to admit that it was not the "true" high-end even though my wallet said it was.[:mousemonkey:4]Sucks sometimes, but that is what enthusiasts must deal with on any hobby... lack o' cash.[:mousemonkey]
"Hey, I'm a reasonable guy, but I've just experienced some very unreasonable things" - Jack Burton
Profile: newbie
More Information
It’s obvious that most of Tom’s readers are “Savvy” and we normally enjoy his articles but I find myself going straight to the conclusion these days. It’s not the writing itself, it’s what there making the writers write about, example: “Stepping on 3year old chips”.
I don’t want this to come off wrong because I do enjoy the web sight.
Signed,
A concerned reader
Profile: Ancient Poster
More Information
One thing that gives the writers/editors a disadvantage is that they need to actually build/test the box.
In a Perfect world, you would have used some GTS SLI cards for less money as noted, but you did not physically have them handy.
As posters, we have the luxury of hand selecting nearly any component on the the internet.
If its good in theory but not in practice,
its not good theory.
Profile: stranger
More Information
I can't agree more about the CPU.  I would even go as far to ask why even go quad core to begin with??  On top of it why even choose a GTX??  An e8400 and an 8800GTS 512 seem like the obvious, if only solution for a mid-range system.  This would bump the cost of the system down considerably.  The system might be under $2000, but not after you buy Windows and all the peripherals required to use the computer.  Keep that in mind.
I agree also agree with the above poster about skipping to the conclusion.  I knew something was wrong when I saw that a Phenom was chosen for the low-end system.  This latest system could be worse, but you guys are way off the mark.  You would suggest a poor component choice (8800GTX) to people if you are "under the gun" as you put it?  Use common sense.
Message edited by sirokket16 on 03-25-2008 at 11:18:07 PM
Profile: journeyman
More Information
@sojrner
Yeah, a while later I was thinking the same thing. Like I said before, I think it's pretty much a difference of tastes aswell.
I think they pull the very high end processor in the charts into the performance category. In that case, you are pretty much correct.
However, as I'm 17 years old, and got my PC from my dad (I helped to pay it aswell) I just don't see the benefit of that processor. But that is offcourse from a financial aspect. Even though my dad might have money to burn, I'd rather have a good system which will last me quite long, and spend money after 5 years for a new system that will perform mid-high.
Do we really benefit from 10 more frames over 60 frames per second.
Anyway, I'm playing the latest games (including crysis) at max (except for crysis). Crysis is a future developing game, that pushes hardware like it is suppost to. I think it's a good kick on the bum for Nvidia and ATI, aswell as INTEL & AMD .
But you are correct. But I'd rather stay for a nice budget what I call a Mid-high budget ($1000+)
Low budget = $500 to $700
High = SLI or XFIRE (2500-+)
Over the top = (3000+)
but that's just a waste of money in my eyes.
It's pretty much a big point of view case. You build what YOU think is good for your wallet. And at the same time have kick-ass performance for what you get. Or you might even overclock and get more performance without pushing your hardware to it's limits (as in temperature, duration etc)
I think it's good to talk about it though, it could support people at tom's making their articles better and more attractive.
Profile: stranger
More Information
I tend to believe that midrange should be determined more by price and not by where benchmarking results fall on a chart. I think that most people would consider a midrange system to be one that was built to have the best performence for about $1500 today. $2000 is just a bit too far over the midrange line for most people.
I've been a system builder for well over a decade. I have never posted her before but after seeing the nearly 2k price tag for a midrange system I was compelled to state my opinion. I'm sure some people will not agree but the fact that you could easily shave off 400-500 to make the 1500 price level and loose MINIMAL performance proves my point.
Heck you could even go for one of the new wolfdale dual cores (and maybe even overclock it) and get good or better performance on a lot of apps because there are not many apps that take advantage of quad core arcitecture at this point(besides encoding and a couple other types of apps that most users arent concerned with). When there are more apps that do take advantage of this you can simply upgrade to a newer quad core for much less than it costs now to get one currently.
The graphics could have easily gotten away with an 8800GTS 512MB, OR please someone tell me why nobody thought of this... 2x 8800gt's (you can get 2 of these for about $460 right now.... If ur already gonna spend $415 on a single graphics card why not just get the 2 8800gt's.
There def need to be more catagories of systems to build. I agree with Ananan, but I would have there be a Low end, Mid, High, and then Ultimate. This system that was built borders the high end in my book.
Matt
Profile: addict
More Information
Maybe the timing was just wrong for a new SBM.
I'm right now sitting in front of the same case and GPU as this build but I built this system in 2006!  I'm excited about finally making the move to a quad core when the mid-range Yorkfields hit but right now that is the only new hardware that is compelling me.  From your last build to this one not enough new has happened in hardware other than much better pricing for a good GPU.
Sniper
More Information
