My rig is as follows
Amd Athlon 64 x2 6000+ with EK Supreme waterblock
Corsair 2048MB TwinX XMS2 6400 DDR2 Memory Kit (2 x 1024MB)
Galaxy 8800 gts 320mb with zalman waterblock
Black Ice GTS Stealth X-flow radiator mounted externally onto side of case with 3 akasa fans and controller 12V Laing DDC-1T Pro w/XSPC Acrylic Pump Top Danger den 2 bay reservoir with 2lt of coolent
Crappy foxcon TSAA908 mid tower case which i cut a hole in with a jigsaw to accommodate the rad.
JEANTECH - 600W ATX modular PSU
500gb Hitachi 7200k sata 2 hd
I've recently bought 4 10,000k 74gb scsi u320 hard drives and i'm not sure whether i should put these in the case or save up and get an external housing. Anyone have any experience with scsi hd's and know how hot they run? External 4 bay case for scsi u320 is about £100 seems abit steep. I'd rather put them in the case with front mounted fan if they'll survive.
Its worth noting the case is cramped and ive been quite messy with my cabling/tubing.
Hope the links work. Please don’t click the links if you’re easily offended by bone idol laziness and incompetent cabling....
Hope some one can help.
Almost forgot temps. CPU is running between 38c idle and load around 43c constantly overclocked at 3.3
GPU running at 43-45c at 600mhz core /850mhz clock. Though i'm usuing internal sensors not temp probe so i guess these are unreliable but its all i got for the moment.
