Tom's Hardware > Forum > Storage > Hard Disks > Hard Drive breaking chassis!?
Forum Storage : Hard Disks - Hard Drive breaking chassis!?
So, I had a hard drive chassis burn out on my the other day. I was told it might be an issue with the wrong power supply. So I looked inside and I saw the burn point, looked like the hard drive might be alright. It was suggested to me to take that hard drive and put it in another chassis to see if that would work. Unfortunately, that chassis immediately burnt out to and the smell was almost immediately noticeable.
My question is, what is going on? I used the exact same chassis it should be in, double check the power supply, how is the hard drive causing the chassis to burn out?
Sponsored Links
The hard drive is probably faulty and is shorting the power supply.
Reply to MrLinux
how does a chassis burn out?
Are we talking about an external hd enclousure?
------------------------------ I am U, R, B, R\B. B\U and U\R
Reply to joz
Yes, sorry it is the enclosure itself that is being burnt out. There's a circuit board that fries in the same spot every time.
Reply to leeb
yea, there is probably a short of some kind on the board on the hard drive. Its happened before. Don't put that drive in anything else, and junk it. If you need the data off of it, you could try swapping the board on the drive with another one from a Drive that is exactly the same (firmware and all) if you have the resources.
------------------------------ Athlon 64 X2 4400+ @2.4GHZ,Zalman CNP9500 LED CPU cooler Asus A8N32-SLI Deluxe, 2GB Corsair XMS-3500LL w/ activity lights, Nvidia 9800GTX 512MB, 2 x 400Gb Western Digital Sata drives, Audigy 2 Zs, PC Power and Cooling Turbo Cool 1Kw
Reply to HVdynamo
I can't junk it, unfortunately, and I have no idea how to swap the board on the drive. I wouldn't really do that, but is there a resource that could explain how I would?
Reply to leeb
There are 1220 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
