Tom's Hardware Forums » Graphic & Displays » Graphics Cards » 21a +12v enough to power an 8800gt?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : 21a +12v enough to power an 8800gt?
Profile: journeyman
More Information
So I have ummm, what do you call it... a crappy PSU :P. 450w, 21a on a single +12v rail.
Can that power an 8800gt and like either a 5000 x2 BE, or one of them 9550 phenoms?
Related Pr oduct
Profile: nimble knuckle
More Information
I don't think so.   My understanding is that a 8800GT system typically should have 26a.  Also, a crappy psu may not even deliver it's advertised power when the temps get over 25c.
E8400-stock, GA-P35-DS3R(rev2.1), Corsair 4x2gb 6400C5, EVGA 8800GTS-512-G92, Vista home premium-64-bit, WD velociraptor-300gb,  PC P&C silencer-610,  Antec SOLO,  2 x Samsung 275T, Samsung-203b-dvd
Profile: Ancient Poster
More Information
No, it's not good for anything. Get another psu. :p
More Information
What PSU do you have?
Profile: enthusiast
More Information
^  Raidmax???
Profile: journeyman
More Information
yes :( raidmax case + psu = ftl
it was my first time building (summer of 06) i was a nob :(
Profile: enthusiast
More Information
Trust me, I know how that goes!  I think everyone here has had a noob PSU experience.
What's your budget for a new PSU?
Profile: journeyman
More Information
well heres the thing, I want to upgrade to a 5000x2 BE or a cheaper phenom, and I want to upgrade my videocard (from a 7900gt) and then I will be good until the nehalems come out. I wanted to keep this whole thing at 300$ but dunno if I can do that with a new PSU.
Any thoughts?
oh also Im going out now, Ill check this thread later
Message edited by ben10218 on 04-04-2008 at 06:58:55 PM
More Information
For my first build I went with a Logysis Case + 450W PSU combo for $40. I seem to recall there being only 18A on the +12V rail, but that thing just sucked all around.
I like my XClio 500W Goodpower, but I wouldn't really recommend it over some of the newer midrange PSUs like the Antec earthwatts series.
Profile: enthusiast
More Information
Hm..., if you're on a really tight budget I'd say go for this: http://www.newegg.com/Product/Prod [...] 6817341012
If you can though, I'd save up for a 500W plus PCP&C, Corsair, or the like.
Profile: addict
More Information
I would doubt it and given that the specs on crappy PSUs are max when hit by lightning even if it did run it wouldn't for very long. Save your money and get a good PSU that will last you a couple of upgrades. Like a PC Power & Cooling or a Silverstone. I have had really good luck with SeaSonic as well. One of the best deals for a good PSU is the PC Power 610w, it has a single 12v rail and is a solid PSU. You can get it for around 119.00. That's 610w continuous power not max big difference. Maximum PC just built a $1,500 rig last month and they used it, they are pretty picky on what they put in a system so if they like it, you know its pretty good.
http://www.newegg.com/Product/Prod [...] 6817703005
http://www.newegg.com/Product/Prod [...] 6817151027
http://www.newegg.com/Product/Prod [...] 6817256006 On sale good price
http://www.newegg.com/Product/Prod [...] 6817256037 Least expensive at $69.00
Message edited by cisco on 04-04-2008 at 07:59:34 PM
More Information
You need 22-23 amps for that system including safety margin with the 9550 Phenom. You can get by with what you have.
Scruze my English!
More Information
Profile: journeyman
More Information
Here is a psu 28a on +12v for $29
http://www.newegg.com/Product/Prod [...] 6817255010
anyway is 20amps good for 8800gs??
Message edited by hsetir on 04-04-2008 at 09:25:13 PM
Sniper
Profile: Forum Veteran
More Information
^ NOOOOO!!!!!! That PSU is cr@p! Its Tire 5 here:
http://www.xtremesystems.org/forum [...] p?t=108088
It also doesn't have a PCIe power.
Message edited by Shadow7037 93 on 04-04-2008 at 09:53:48 PM
E2180 @3.2Ghz + P35DS3L +8400GS (700/475 OC)
http://farm4.static.flickr.com/3268/2588429538_b3c41b29c3.jpg
Add a reply
Google Ads
