Could this be a PSU problem??
Word :   Username :
Bottom
Author
 Thread : Could this be a PSU problem??
Profile: stranger
More Information
purchased a new system, installation was 100 percent problem free but start up, or lack there of, has been 100 percent problematic.
push the power button, and absolutely no power at all. its not like its turning on then immediately shutting off, nothing happens at all when i hit the power button.
yesterday, it would flash a bit of light, and the keyboard would light up for a sec but today absolutely nothing.
ive narrowed it down to the mostly likely culprits and i think its either mobo or psu, but im going with the psu as the box was badly damaged on delivery. I kno its a solid psu, but nothing is good when its been mishandled and abused.
GIGABYTE GA-P35-DS3L LGA 775
MSI NX8800GTS 512M OC GeForce 8800GTS
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor
Crucial Ballistix Tracer 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
CORSAIR CMPSU-550VX ATX12V V2.2 550W Power Supply - Retail
Message edited by xplicid001 on 04-25-2008 at 06:23:35 AM
Related Product
...I like you
Profile: addict
More Information
Probably PSU then.
"He is no fool who gives what he cannot keep to gain what he cannot lose" -- Jim Elliott
Profile: addict
More Information
Are you sure nothing is shorting out? Have you used standoffs so your motherboard isn't touching your case?
If neither of those, then I would say it would be a PSU issue.
Profile: stranger
More Information
theres no short and of course i used the raisers ;P
neways i was able to take the psu and use it in another system i have, a78nx mobo (classic for **** sure) and the psu would start up for ten seconds before dieing. now, i have mixed emotions from this result. for one, i kno the psu is faulty, but the fact it booted up for ten seconds leads me to believe that the MOBO might be fried too?
Republic of California
Profile: nimble knuckle
More Information
I stopped useing/buying or telling people to use Antec 10 years ago.
Get a real PSU...get a PC Power & Cooling PSU or at least the next step down a Silverstone like Falcon Northwest puts into thier 5-15K USD custom builds.
I always wonder why people over the years spend the big bucks for every part of thier system and turn around and use a crap PSU which is the #1 most important thing to use.
Message quoted 1 times
Message edited by ZOldDude on 04-25-2008 at 08:46:12 AM
*While we crash and burn, small, low tech, agrarian societies such as the Hmong in the mountains of Laos will continue on without so much as blinking an eye.*
Why so SeRiOuS?
Profile: old hand
More Information
Its called cutting corners. Most people can understand speed for memory, cpu or a video card to be important and can visually see the difference in the charts listed or on the retail boxes themselves.
Power supplies is the most misleading item to buy for a pc. The average user doesnt know that "not all 500 watt psus are created equal" or any other voltage psu for that matter so they buy whatever has the voltage advertised at the best price.
Its an honest mistake and I would be confident to say that we have all bought a cheapo psu at some point to save a buck without realizing what we were really doing....
After all, a what is a watt is a what, right? ;)
Message edited by englandr753 on 04-25-2008 at 06:43:15 PM
Sailing in my Dreams
Profile: Forum Veteran
More Information
To be honest, I did buy a cheapo PSU once. Learned my lesson and never repeated it. I once read that a person should add up the cost of the computer build and figure 10% of that for a PSU. In other words, a $1000 build should have a $100 PSU and a $2000 build should have a $200 PSU, and so forth. Still have to read reviews and buy the best PSU you can for the money, but it is a guideline. Fortunately, PSU cost have come down a bit so that you might not have to spend the 10%, but the basic idea remains. Don't go cheap on the PSU. Like ZOldDude says, the PSU is the #1 most important thing. Without it, everything else is just a pile of parts.
Evil lurks in the databanks as it lurked in the streets of yesteryear. But it was never the streets that were evil.
Over 50. Seen it, done it, can't remember it.
Profile: addict
More Information
That's because 10 years ago Antec was crap, they've turned around since the NeoHE and Earthwatts came out, using a quality OEM like SeaSonic instead of using cheap FSP and CWT units(Although FSP and CWT make some good stuff, they make crappy stuff on the low end also). Although he did say he used a Corsair unit, a unit which has got plenty of good reviews around the net and is hardly low quality. My guess is you just got unlucky with the power supply and it damaged something else, but I can't really tell you for sure what it damaged.
Google Ads
News
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Patch issued for OpenOffice.org WMF vulnerability
Published on January 05, 2007
A patch has been released for a vulnerability in the OpenOffice.org productivity suite, a problem rated as "highly critical". Read more
Image processing flaw found in Firefox
Published on May 17, 2006
Firefox users may be vulnerable to a denial of service attack after researchers looked into reports of a new vulnerability within Firefox 1.5.0.3. Read more
Nano-welding could join molecular devices
Published on March 31, 2006
A nanoscale welding technique has been developed by sparking high-temperature chemical reactions inside "nanopores". Read more
Latest Reviews & Articles
Seagate's 1.5TB Barracuda: Bigger And Better?
Published on October 02, 2008
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
Stalker: Clear Sky - Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
