possible psu problem
Word :   Username :
Bottom
Author
 Thread : possible psu problem
Profile: stranger
More Information
My computer boots but there is no signal to the montor. There are no sounds from the speaker so I assume its not the motherboard (though I have tried another motherboard).
I've tried 3 different graphics cards so it can't be that.
I've tried 2 different cpus.
All of this on 2 different motherboards (I had access to a friends.)
should post current specs I suppose
AMD 4000+ AM2
Asus M2N motherboard
1 gb Crucial ram (1 stick)
Geforce 8800gts (evga)
I have a 500w generic powersupply I've tried 3 different graphics cards- a 6600gt, a 7600gt, and a 8800gts. The computer boots to the same state with all of them, but as stated there is no signal
Could this be a power supply issue? I am using a generic pos 500w.
I was also thinking it could be the ram, but there is no ram error through the speaker.
I was just hoping to get some input before I drop money on psu
thanks
Related Product
Profile: Ancient Poster
More Information
Yeah. It could be the power supply. Check the 12v rail ratings on the sticker, and be sure the correct lead is connected to your gts. I would get one of these brands: fortron (sparkle), enermax, antec, corsair, seasonic, or pc power and cooling. You can also try a bare post on a non conductive surface such as the box the board came in or a phonebook. Take the board out of the case; use just one memory stick, cpu/heatsink, and video card. You may have to remove the power supply from the case for the leads to reach the board; connect all the ps leads to the board and video card. Only one you may not need is the power switch lead off the case. You can start the system by touching the power switch leads (2 pins on the board) with a plain screwdriver.
Message edited by o1die on 04-25-2008 at 02:10:20 PM
Profile: enthusiast
More Information
z0r- I have to agree with z0r- Check the 12v rail ratings on the sticker, and be sure the correct lead is connected to your gts. don't know if it's a 512,320,640 . does the psu show 12 + volt @ what amps?
GIGABYTE p35 ds3l-- e8400 wolfdale-- 4 GIG RAM g.skill 800 -- xfx 9800gtx 512-- OCZ 700 POWER SUPPLY---NZXT Apollo BLUE NP Blue SECC Steel Chassis ATX Mid Tower---acer 2216 wide screenl---logitech 3000 keyboard and mouse--- vista 32 bit
Profile: Forum Veteran
More Information
zor, how do you know the computer boots? Do you hear the "starting Windows" music?
e2160@3GHz: OCing my way to Ubuntuland!
jsc
Profile: old hand
More Information
Boots, but no signal to the monitor. What does that mean?
When you say there are no sounds to the speaker, do you mean the little internal one that gives a single short beep when everything is good before Windows loads? Or do you mean the external audio speakers where real sound comes from?
Profile: stranger
More Information
I had access to a friends psu yesterday. 600w Antec. I get the same results I've described.
Basically, it looks like the monitor is broken, but its not. That's what "no signal" means.
I get the same results when I took the motherboard out of the case and put it on my wooden table. I've even tried another case.
Profile: stranger
More Information
Profile: stranger
More Information
I should also say this is completely new. Haven't done anything with the bios, loaded windows, or anything.
Profile: stranger
More Information
This isn't psu related anymore, but since this thread is already here I'll just post here.
With nothing left to do, I decided to pull the cpu. When I took the fan off, the cpu came off adhered to the fan because of the crappy amd thermal paste. There is no speaker beep error (like there should be) but the rest of the computer acts the same, meaning all the fans start up, gpu fan starts. LCDs on the case work, as well does the lcd on the board (asus n2m).
Basically, I think 2 of my processors were bad. I honestly couldn't believe 2 in a row could be bad. I'm basically going to borrow one from my friend who works at a computer store to test my theory.
Any other suggestions would be appreciated, though I'm not sure there is absolutely anything else it can be. I'll keep posting since it won't hurt.
More Information
1) It could be the RAM.
2) Hook up a cheap Radio Shack speaker to the speaker header so you can hear the beep error code, which might point you in the right direction.
Google Ads
News
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
90% of email estimated to be spam
Published on November 28, 2006
Despite rampant attempts to squash spammers, a new report from Internet messaging company Postini says that 9 out of every 10 e-mails is junk, an amount that is reportedly triple from what it was six months ago. Read more
Nvidia Contract Makers In Taiwan Low-key Over Defective Chip Reports
Published on July 07, 2008
Nvidia's Taiwan-based graphics chip contract makers are being low-key after the US chip designer informed investors on July 3 that will take a charge of US$150-$200 million related to expenses stemming from issues discovered with die/packaging materials used in previous generation notebook products. Read more
XP Service Pack 3 Kills AMD Machines
Published on May 09, 2008
Windows XP Service Pack 3 finally arrived to our computers this week… And is now killing AMD machines, according to Jesper Johansson, former program manager for security policy at Microsoft. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
