When I want to setup the nvidia 174.74 WinXP 32bit driver everytime it shows the error says:
"The nvidia setup program could not locate any drivers that are compatible with your current hardware. Setup will now exit."
I am using XFX GTS 8800GTS 512 MB(G92). I downloaded the driver from nvidia site first then from guru3d. Others are saying they are using it fine but whats the problem of mine? I am currently using 169.25. BTW I also flashed it when I wanted to install the 174.74 version.
