Tom's Hardware > Forum > Storage > Flash Media > USB Flash Drive: Doesn't work anymore
Forum Storage : Flash Media - USB Flash Drive: Doesn't work anymore
Well my flash drive used to work but today when I plugged it in it didn't work, no light came on the device or anything. Is it anyway for me to get my information off the drive since its no longer working in any computer?
Sponsored Links
The drive is toast! It has been disconnected from the computer without using the windows disconnect hardware tool that is in the lower right hand tray on the screen. It is now pretty much useless and is good to use as a reminder of why people should not disconnect a usb drive without disconnecting it in windows first. Sorry
Message edited by shabaa on 05-18-2009 at 02:23:22 PM
Reply to shabaa
"The drive is toast! It has been disconnected from the computer without using the windows disconnect hardware tool that is in the lower right hand tray on the screen. It is now pretty much useless and is good to use as a reminder of why people should not disconnect a usb drive without disconnecting it in windows first. Sorry"
same thing happened to me, so i can't retrive all my documents on it?
and when i did remove my usb the computer was turned off and i already had safely removed the device.
Reply to Anonymous
There are 881 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
