Problems installing OS
Forum Motherboards & Memory : General Motherboard - Problems installing OS
While installing Vista Ultimate 64bit on my new Rampage Formula I got the following information on the screen when it tried to reboot;
free DOS Kernel version 1.1.35w(build 2035w-unstable, nov 30 2005)
Kernel compatibility 7.10 WACOMC fat32 support
Copyright 1995-2005 Pasquale Villani and the free DOS Project
No warranty Licensed under the GNU general public licence version 2
c:DH1, Pri [1], chs=0-1-1-, start =omb size 31Mb
Bad or missing Comand interpreter enter the full shell command line:
Command.com IP IE:256
Somewhere I read something about this being a problem with SATA Optical drives. Does anyone have any information on this? You can see my hardware setup in my sig.
------------------------------ http://valid.x86-secret.com/cache/banner/450637.png
Sponsored Links
There's a problem with at least some versions of Vista installing when you have 4GB of RAM installed. In any case, before installing Vista, make sure your system is stable, since essentially all RAM sold these days as faster than DDR2-800 is really overclocked, requiring higher-than-standard voltages. This often causes problems on new installs, since the MB cannot automatically set the RAM voltage higher than the standard 1.8V.
Download and run memtest86+ (it's available as a bootable floppy or CD image file, which doesn't require an OS installed to run) and make sure there are no errors after at least two full passes.
------------------------------ e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
I had only 2GB of RAM installed and I had setup the BIOS for this RAM by setting the freq. to 1066MHz and timings to 5-5-5-15-8 2T and raised the DRAM voltage to 2.20v which are the factory spec's and I set the NB to 1.31v. So I don't think it is the RAM. I have another computer I was putting together at the same time that did the same thing. I was trying to load XP Pro on it and got the same message. The two things these computers have in common are the SATA Optical drives, which by the way are different brands, and they both have ASUS motherboards.
I am at a loss and have sent ASUS a tech request. I think in the mean time I will try to load the OS using IDE Optical drives and see what happens.
Thx's Mondoman for your input and I will return when I have news to report.
Reply to dallasjoh
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Problems installing OS
There are 514 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
