Right so im having abit of a problem with Windows Vista (Anybody suprised??!) Anyway.... I have 2 sticks of Corsair XMS2 memory, its DDRII PC26400. Them problem is my vista rating for my memory. Its only getting a 4.8 which is my lowest subscore. My system should be at least a 5 - 5.3 (which is my CPU). My specs are:
Intel Core 2 Duo E4600 2.4GHZ stock
2GB DDRII PC2-6400
Intel DP965LT Motherboard
Radeon HD 3870 PCi-E
I have gone into my bios and the memory mode is set to dual channel, and the sticks are in the right slots but still with the 4.8.
Can anybody help, or point me in the right direction? This probably isnt even an issue, my machine runs fine, plays all the games I want it to and is brilliant for video encoding. I may be wrong but I feel im missing out on a little speed with such a low rating for supposed 'Performance' memory.
Vista is a bit of a memory whore.
RAM is cheap. Double what you have and go from there.
------------------------------If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
I have tried 4GB using 4 of the same sticks (i borrowed 2 XMS2 sticks from my brothers machine) and still got 4.8 but I am only using 23-35% of my usual 2GB so the usage is not an issue.
The XMS2 memory is performance memory which should be getting a rating of 5 or higher from reading around the internet, but mine is only at 4.8.
The desktop board supports the dual or single channel memory configurations defined
below.
• Four 240-pin Double Data Rate 2 (DDR2) SDRAM Dual Inline Memory Module
(DIMM) connectors with gold-plated contacts.
• Support for:
⎯ Unbuffered, non-registered single or double-sided DIMMs
⎯ Non-ECC DDR2 memory
⎯ DIMM Type and Timings listed below:
Type Timing
DDR2-800 5-5-5 or 6-6-6 only
DDR2-667 5-5-5 only
DDR2-533 4-4-4 only
⎯ Serial Presence Detect (SPD) memory only
⎯ Memory configurations listed below:
• Up to 2.0 GB utilizing 256 Mb technology
• Up to 4.0 GB utilizing 512 Mb or 1 Gb technology
• Up to 8.0 GB utilizing 1 Gb technology
My memory is 4-4-4-12 does this mean i can run it?? My memory is DDRII 800MHZ but this mentions 5-5-5 or 6-6-6 only for DDRII 800?? confused.
