Yes No
Ads
Direct 3D Problem
Forum Graphics & Displays : Graphics Cards Direct 3D Problem
My problem is that i cant run any application that requires 3D so i did the directX diagnostic and it said that Direct 3D is not available but it worked properly before. It says not available in the display tab and i cant click the enable/disable button. Common errors i get in display are D3DERR_NOTAVAILABLE and dll not initialized.
I already tried downloading the lastest driver upgrades from the manufacturer and downloading the latest DirectX updates. I have tried in diferent forums but no one can solve the problem. For almost 3 months i been having this problem if someone knows how to solve this plz post.
I am posting the directx diag report if its of any help:
System Information
Time of this report: 4/7/2008, 10:23:22
Machine name: JACUNA
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: English (Regional Setting: Spanish)
System Manufacturer: Gateway
System Model: Gateway M320 and 4500 Series
BIOS: Rev 1.0
Processor: Intel(R) Pentium(R) M processor 1.60GHz
Memory: 478MB RAM
Page File: 569MB used, 550MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Sound Tab 2: The file btaudio.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) 82852/82855 GM/GME Graphics Controller
Manufacturer: Intel Corporation
Chip type: Intel(R) 82852/82855 GM/GME Controller
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_3582&SUBSYS_203E161F&REV_02
Display Memory: n/a
Current Mode: 1280 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ialmrnt5.dll
Driver Version: 6.14.0010.4497 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 2/7/2006 08:56:16, 45697 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ialmnt5.sys
Mini VDD Date: 2/7/2006 09:04:34, 1399615 bytes
Device Identifier: {D7B78E66-76C2-11CF-3E64-3400A3C2CB35}
Vendor ID: 0x8086
Device ID: 0x3582
SubSys ID: 0x203E161F
Revision ID: 0x0002
Revision ID: 0x0002
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SoundMAX Digital Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_8086&DEV_24C5&SUBSYS_203E161F&REV_03
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: smwdm.sys
Driver Version: 5.12.0001.5240 (English)
WHQL Logo'd: Yes
Date and Size: 9/1/2004 15:17:46, 259648 bytes
Other Files:
Driver Provider: Analog Devices
HW Accel Level: Full
Cap Flags: 0xB5B
Min/Max Sample Rate: 8000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Description: Audio Bluetooth
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: {95C7A0A0-3094-11D7-A202-00508B9D7D5A}\BTAUDIO
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: btaudio.sys
Driver Version: 3.00.0001.0914 (English)
WHQL Logo'd: No
Date and Size: 11/2/2004 10:50:46, 17024 bytes
Other Files:
Driver Provider: WIDCOMM Inc.
Cap Flags: 0x959
Min/Max Sample Rate: 8000, 8000
HW Memory: 0
Registry: OK
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCCC
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x41
Format Flags: 0x4
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
SoundMAX Digital Audio, Software (Kernel Mode), Output, DLS, Internal
Audio Bluetooth, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24C4
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/4/2004 14:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 14:00:00, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 07:58:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 10:01:08, 40840 bytes
+ Synaptics PS/2 Port TouchPad
| Matching Device ID: *syn0b01
| Upper Filters: SynTP
| Service: i8042prt
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: mouclass.sys, 8/4/2004 07:58:34, 23040 bytes
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Conexant SoftK56 Data Fax Modem
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 Serial Service Provider: COM4
DirectPlay8 TCP/IP Service Provider: Wireless Network Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 19.6 GB
Total Space: 53.4 GB
File System: NTFS
Model: IC25N060ATMR04-0
Drive: D:
Free Space: 1.7 GB
Total Space: 3.8 GB
File System: FAT32
Drive: E:
Model: HL-DT-ST DVD-RW GWA-4080N
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Spanish), 8/4/2004 14:00:00, 49536 bytes
System Devices
Name: Intel(R) PRO/Wireless 2200BG Network Connection
Device ID: PCI\VEN_8086&DEV_4220&SUBSYS_27018086&REV_05\4&25B5B1E3&0&48F0
Driver: C:\WINDOWS\system32\DRIVERS\w22n51.sys, 8.00.0012.9000 (English), 1/2/2004 04:52:34, 1646720 bytes
Driver: C:\WINDOWS\system32\w22NCPA.dll, 8.00.0000.0119 (English), 11/16/2003 11:33:42, 344064 bytes
Name: Intel(R) 82852/82855 GM/GME/PM/GMV to Processor I/O Controller - 3585
Device ID: PCI\VEN_8086&DEV_3585&SUBSYS_203E161F&REV_02\3&61AAA01&1&03
Driver: n/a
Name: Intel(R) 82852/82855 GM/GME/PM/GMV to Processor I/O Controller - 3584
Device ID: PCI\VEN_8086&DEV_3584&SUBSYS_203E161F&REV_02\3&61AAA01&1&01
Driver: n/a
Name: Intel(R) 82852/82855 GM/GME Graphics Controller
Device ID: PCI\VEN_8086&DEV_3582&SUBSYS_203E161F&REV_02\3&61AAA01&1&11
Driver: C:\WINDOWS\system32\DRIVERS\ialmnt5.sys, 6.14.0010.4497 (English), 2/7/2006 09:04:34, 1399615 bytes
Driver: C:\WINDOWS\system32\ialmrnt5.dll, 6.14.0010.4497 (English), 2/7/2006 08:56:16, 45697 bytes
Driver: C:\WINDOWS\system32\ialmdnt5.dll, 6.14.0010.4497 (English), 2/7/2006 08:56:08, 121470 bytes
Driver: C:\WINDOWS\system32\ialmdev5.dll, 6.14.0010.4497 (English), 2/7/2006 08:55:58, 232733 bytes
Driver: C:\WINDOWS\system32\ialmdd5.dll, 6.14.0010.4497 (English), 2/7/2006 09:03:32, 956029 bytes
Driver: C:\WINDOWS\system32\igxpxa32.cpa, 2/7/2006 08:30:58, 524850 bytes
Driver: C:\WINDOWS\system32\igxpxa32.vp, 2/7/2006 08:30:58, 929 bytes
Driver: C:\WINDOWS\system32\igxpxk32.vp, 2/7/2006 08:30:58, 58704 bytes
Driver: C:\WINDOWS\system32\igxpxs32.vp, 2/7/2006 09:27:44, 26752 bytes
Driver: C:\WINDOWS\system32\oemdspif.dll, 3.00.0000.4497 (English), 2/7/2006 08:40:06, 57344 bytes
Driver: C:\WINDOWS\system32\hccutils.dll, 3.00.0000.4497 (English), 2/7/2006 08:34:56, 73728 bytes
Driver: C:\WINDOWS\system32\igfxsrvc.dll, 3.00.0000.4497 (English), 2/7/2006 08:35:58, 61440 bytes
Driver: C:\WINDOWS\system32\igfxsrvc.exe, 3.00.0000.4497 (English), 2/7/2006 08:35:58, 163840 bytes
Driver: C:\WINDOWS\system32\igfxpph.dll, 3.00.0000.4497 (English), 2/7/2006 08:39:06, 143360 bytes
Driver: C:\WINDOWS\system32\igfxcpl.cpl, 3.00.0000.4497 (English), 2/7/2006 08:38:52, 81920 bytes
Driver: C:\WINDOWS\system32\igfxcfg.exe, 3.00.0000.4497 (English), 2/7/2006 08:38:44, 450560 bytes
Driver: C:\WINDOWS\system32\igfxdev.dll, 3.00.0000.4497 (English), 2/7/2006 08:35:12, 139264 bytes
Driver: C:\WINDOWS\system32\igfxdo.dll, 3.00.0000.4497 (English), 2/7/2006 08:36:12, 86016 bytes
Driver: C:\WINDOWS\system32\igfxtray.exe, 3.00.0000.4497 (English), 2/7/2006 08:39:20, 94208 bytes
Driver: C:\WINDOWS\system32\igfxzoom.exe, 3.00.0000.4497 (English), 2/7/2006 08:39:48, 114688 bytes
Driver: C:\WINDOWS\system32\hkcmd.exe, 3.00.0000.4497 (English), 2/7/2006 08:36:06, 77824 bytes
Driver: C:\WINDOWS\system32\igfxress.dll, 3.00.0000.4497 (English), 2/7/2006 08:39:10, 1503232 bytes
Driver: C:\WINDOWS\system32\igfxpers.exe, 3.00.0000.4497 (English), 2/7/2006 08:40:02, 118784 bytes
Driver: C:\WINDOWS\system32\igfxrara.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:10, 126976 bytes
Driver: C:\WINDOWS\system32\igfxrchs.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:10, 81920 bytes
Driver: C:\WINDOWS\system32\igfxrcht.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:10, 81920 bytes
Driver: C:\WINDOWS\system32\igfxrdan.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:12, 139264 bytes
Driver: C:\WINDOWS\system32\igfxrdeu.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:12, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrenu.lrc, 3.00.0000.4497 (English), 2/7/2006 08:35:16, 135168 bytes
Driver: C:\WINDOWS\system32\igfxresp.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:14, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrfin.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:14, 143360 bytes
Driver: C:\WINDOWS\system32\igfxrfra.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:14, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrheb.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:14, 122880 bytes
Driver: C:\WINDOWS\system32\igfxrita.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:16, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrjpn.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:16, 98304 bytes
Driver: C:\WINDOWS\system32\igfxrkor.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:16, 98304 bytes
Driver: C:\WINDOWS\system32\igfxrnld.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:16, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrnor.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:18, 139264 bytes
Driver: C:\WINDOWS\system32\igfxrplk.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:18, 143360 bytes
Driver: C:\WINDOWS\system32\igfxrptb.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:18, 143360 bytes
Driver: C:\WINDOWS\system32\igfxrptg.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:18, 147456 bytes
Driver: C:\WINDOWS\system32\igfxrrus.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:20, 143360 bytes
Driver: C:\WINDOWS\system32\igfxrsve.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:20, 139264 bytes
Driver: C:\WINDOWS\system32\igfxrtha.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:20, 131072 bytes
Driver: C:\WINDOWS\system32\igfxrcsy.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:12, 143360 bytes
Driver: C:\WINDOWS\system32\igfxrell.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:12, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrhun.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:14, 147456 bytes
Driver: C:\WINDOWS\system32\igfxrtrk.lrc, 3.00.0000.4497 (English), 2/7/2006 08:40:20, 139264 bytes
Driver: C:\WINDOWS\system32\igfxext.exe, 3.00.0000.4497 (English), 2/7/2006 08:39:54, 94208 bytes
Driver: C:\WINDOWS\system32\igfxexps.dll, 3.00.0000.4497 (English), 2/7/2006 08:39:54, 40960 bytes
Driver: C:\WINDOWS\system32\ialmrem.dll, 6.14.0010.4497 (English), 2/7/2006 08:56:12, 49152 bytes
Driver: C:\WINDOWS\system32\iglicd32.dll, 6.14.0010.4497 (English), 2/7/2006 08:46:40, 2310144 bytes
Driver: C:\WINDOWS\system32\igldev32.dll, 6.14.0010.4497 (English), 2/7/2006 08:48:30, 524288 bytes
Driver: C:\WINDOWS\system32\ialmudlg.exe, 0.00.0000.0000 (English), 2/7/2006 08:40:38, 114688 bytes
Driver: C:\WINDOWS\system32\ialmuARA.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:38, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuARB.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:38, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuCHS.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:38, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuCHT.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:38, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuCSY.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:44, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuDAN.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:38, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuDEU.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:40, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuELL.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:44, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuENG.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:40, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuESP.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:40, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuFIN.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:40, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuFRA.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:40, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuFRC.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:40, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuHEB.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:40, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuHUN.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:44, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuITA.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:42, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuJPN.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:42, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuKOR.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:42, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuNLD.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:42, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuNOR.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:42, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuPLK.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:42, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuPTB.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:42, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuPTG.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:42, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuRUS.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:44, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuSVE.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:44, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuTHA.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:44, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuTRK.dll, 0.00.0000.0000 (English), 2/7/2006 08:40:44, 40960 bytes
Driver: C:\WINDOWS\system32\iAlmCoIn_v4497.dll, 1.00.1000.0001 (English), 2/7/2006 08:56:10, 61440 bytes
Device ID: PCI\VEN_8086&DEV_3582&SUBSYS_203E161F&REV_02\3&61AAA01&1&10
Name: Intel(R) 82852/82855 GM/GME/PM/GMV to Processor I/O Controller - 3580
Device ID: PCI\VEN_8086&DEV_3580&SUBSYS_00000000&REV_02\3&61AAA01&1&00
Driver: n/a
Name: Intel(R) 82801DB/DBM USB2 Enhanced Host Controller - 24CD
Device ID: PCI\VEN_8086&DEV_24CD&SUBSYS_203E161F&REV_03\3&61AAA01&1&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 03:56:44, 7168 bytes
Name: Intel(R) 82801DBM LPC Interface Controller - 24CC
Device ID: PCI\VEN_8086&DEV_24CC&SUBSYS_00000000&REV_03\3&61AAA01&1&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Name: Intel(R) 82801DBM Ultra ATA Storage Controller - 24CA
Device ID: PCI\VEN_8086&DEV_24CA&SUBSYS_203E161F&REV_03\3&61AAA01&1&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 16:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Spanish), 8/4/2004 01:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 01:59:44, 95360 bytes
Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C7
Device ID: PCI\VEN_8086&DEV_24C7&SUBSYS_203E161F&REV_03\3&61AAA01&1&EA
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
Name: Conexant SoftK56 Data Fax Modem
Device ID: PCI\VEN_8086&DEV_24C6&SUBSYS_2030161F&REV_03\3&61AAA01&1&FE
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_CNXT.sys, 7.04.0001.0000 (English), 10/14/2003 21:05:48, 679808 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSFHWICH.sys, 7.04.0001.0000 (English), 10/14/2003 21:08:22, 197120 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_DP.sys, 7.04.0001.0000 (English), 10/14/2003 21:04:16, 1043072 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0002.0002 (English), 4/9/2003 18:48:08, 11043 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\ask2030.cty, 12/16/2003 17:06:12, 128333 bytes
Driver: C:\WINDOWS\system32\mdmxsdk.dll, 1.00.0002.0002 (English), 4/9/2003 19:01:32, 90112 bytes
Driver: C:\Program Files\CONEXANT\CNXT_MODEM_PCI_VEN_8086&DEV_24C6&SUBSYS_2030161F\HXFSetup.exe, 2.01.0008.0000 (English), 10/30/2003 20:25:38, 532480 bytes
Driver: C:\WINDOWS\system32\HSFCI007.dll, 7.00.0000.0000 (English), 8/7/2003 15:17:54, 27786 bytes
Name: SoundMAX Integrated Digital Audio
Device ID: PCI\VEN_8086&DEV_24C5&SUBSYS_203E161F&REV_03\3&61AAA01&1&FD
Driver: n/a
Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C4
Device ID: PCI\VEN_8086&DEV_24C4&SUBSYS_203E161F&REV_03\3&61AAA01&1&E9
Name: Intel(R) 82801DB/DBM SMBus Controller - 24C3
Device ID: PCI\VEN_8086&DEV_24C3&SUBSYS_203E161F&REV_03\3&61AAA01&1&FB
Driver: n/a
Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C2
Device ID: PCI\VEN_8086&DEV_24C2&SUBSYS_203E161F&REV_03\3&61AAA01&1&E8
Name: Intel(R) 82801DBM PCI Bridge - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_00000000&REV_83\3&61AAA01&1&F0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
Name: Broadcom 440x 10/100 Integrated Controller
Device ID: PCI\VEN_14E4&DEV_4401&SUBSYS_203E161F&REV_01\4&25B5B1E3&0&40F0
Driver: C:\WINDOWS\system32\DRIVERS\bcm4sbxp.sys, 4.23.0000.0000 (English), 9/26/2003 12:41:12, 44032 bytes
Name: Texas Instruments PCIxx21 Integrated FlashMedia Controller
Device ID: PCI\VEN_104C&DEV_8033&SUBSYS_203E161F&REV_00\4&25B5B1E3&0&3BF0
Driver: C:\WINDOWS\system32\DRIVERS\tifm21.sys, 1.00.0001.0008 (English), 7/13/2004 16:00:00, 67968 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8032&SUBSYS_203E161F&REV_00\4&25B5B1E3&0&3AF0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 02:10:10, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 02:10:08, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 16:46:40, 6400 bytes
Name: Texas Instruments PCIxx21/x515 Cardbus Controller
Device ID: PCI\VEN_104C&DEV_8031&SUBSYS_203E161F&REV_00\4&25B5B1E3&0&38F0
Driver: C:\WINDOWS\system32\DRIVERS\pcmcia.sys, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 119936 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 14:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 14:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 14:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 82432 bytes
system.dll: 1.01.4322.2407 English Final Retail 7/10/2007 19:24:15 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 4/6/2008 11:31:55 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 4/6/2008 11:31:45 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 4/6/2008 11:31:46 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 4/6/2008 11:31:47 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 4/6/2008 11:31:47 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 4/6/2008 11:31:49 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 4/6/2008 11:31:49 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 4/6/2008 11:31:50 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 4/6/2008 11:31:51 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 4/6/2008 11:31:52 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 4/6/2008 11:31:56 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 4/6/2008 11:31:56 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 4/6/2008 11:31:57 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 4/6/2008 11:31:57 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 4/6/2008 11:31:58 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 4/6/2008 11:31:54 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 4/6/2008 11:31:55 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 4/6/2008 11:31:54 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 14:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 14:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 14:00:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 05:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 20480 bytes
qasf.dll: 10.00.0000.3646 English Final Retail 9/22/2004 18:46:02 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 733696 bytes
quartz.dll: 6.05.2600.3243 English Final Retail 10/29/2007 17:43:03 1287680 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 10:52:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 14:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 14:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 14:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 14:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 14:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 14:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 14:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 14:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 204288 bytes
ks.sys: 5.03.2600.2180 Spanish Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 Spanish Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 Spanish Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 Spanish Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 Spanish Final Retail 8/4/2004 01:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 Spanish Final Retail 8/4/2004 01:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 Spanish Final Retail 8/4/2004 01:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 Spanish Final Retail 8/4/2004 07:58:42 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.3243
CyberLink DVD Navigator,0x00600000,0,3,CLNAVX.ax,5.00.0000.1717
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,1.00.0003.0093
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.3243
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.3243
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.3243
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.3243
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Effect,0x00200000,1,1,claudfx.ax,5.00.0000.1028
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero QuickTime(tm) Video Decoder,0x00600000,1,1,NeQTVDec.ax,1.00.0000.0002
CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLine21.ax,4.00.0000.3030
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.3243
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
Slide Video to MPEG1,0x00000000,0,0,,
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.3243
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.ax,5.00.0000.1031
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,2.00.0002.0007
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.3243
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.3243
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.3243
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
LEAD MCMP/MJPEG Codec,0x00100000,1,1,LCODCCMP.DLL,1.00.0000.0016
LEAD MCMP/MJPEG Decoder,0x00800000,1,1,LCODCCMP.DLL,1.00.0000.0016
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3646
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,5.00.0000.1029
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,5.00.0000.1031
CyberLink TimeStretch Filter,0x00200000,1,1,CLAuTS.ax,1.00.0000.0704
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.3243
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,2.00.0001.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1010
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.3243
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.3243
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.3243
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0006
Nero QuickTime(tm) Audio Decoder,0x00600000,1,1,NeQTADec.ax,1.00.0000.0002
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,2.00.0001.0000
Nero Digital Parser,0x00600000,0,3,NDParser.ax,2.00.0002.0007
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
LEAD Video Color Filter,0x00000000,0,0,,
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.3243
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.3243
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.3243
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Panasonic Video Renderer,0x00000002,1,0,WMRVid.ax,1.01.0000.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.3243
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
HPOD RunTimeline Filter,0x00000000,0,0,,
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.3243
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.3243
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.3243
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.3243
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.3243
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.3243
Audio Capture Sources:
SoundMAX Digital Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Audio Bluetooth,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.3243
WDM Streaming Capture Devices:
SoundMAX Digital Audio,0x00200000,3,2,,5.03.2600.2180
Audio Bluetooth,0x00200000,2,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
SoundMAX Digital Audio,0x00200000,1,0,quartz.dll,6.05.2600.3243
CyberLink Audio Renderer,0x00200000,1,0,CLADR.ax,5.00.0000.1006
Audio Bluetooth,0x00200000,1,0,quartz.dll,6.05.2600.3243
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.3243
DirectSound: Audio Bluetooth,0x00200000,1,0,quartz.dll,6.05.2600.3243
DirectSound: SoundMAX Digital Audio,0x00200000,1,0,quartz.dll,6.05.2600.3243
LTMM Video Processors:
WDM Streaming System Devices:
SoundMAX Digital Audio,0x00200000,7,2,,5.03.2600.2180
Audio Bluetooth,0x00200000,5,2,,5.03.2600.2180
Reply to jotech
plz post any idea
Reply to jotech
Try uninstalling the video card driver, then reinstall it, then DirectX. Also make sure the Hardware Acceleration slider on the Troubleshooting tab for Display Properties is set to maximum. If it's still a no go I'd just put in a new video card, as the Intel onboard is pretty weak. You are downloading the DirectX redistributable, right? There's also a version for developers...might be worth a try.
Reply to Orion1024
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Direct 3D Problem
There are 2023 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bad PCI-E Slot or Bad Graphics Card?
By smorizio, 1 hour ago:
check that you have all the power cables plugged into your video card..some have one some...
Best offers
Top experts
