Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > What kind of wireless device do I need?
Forum Wireless Networking : Setup, Configuration & Security - What kind of wireless device do I need?
I want to put two ethernet wired computers on my wireless connection. I can't run a network cable between my current wireless router and these two computers. What I want to do is get a wireless access point that will pick up my wireless internet and allow me to plug a simple network switch into it, and then connect the two computers to the switch.
Maybe I am not completely understanding the terminology and any regular wireless access point will allow me to plug in a switch? Or do I need something else, like something that says its a bridge?
btw would something like this work?
http://www.newegg.com/Product/...x [...] 6833127146
Or would I need something that says it's a bridge:
http://www.newegg.com/Product/...x [...] 6833180035
Thanks.
Message edited by techs on 05-19-2009 at 02:51:28 PM
Sponsored Links
The links unfortunately do not work. I think a better solution would be to get the wireless access point and equip both PCs with their own wireless adapters (those USB plug-and-play variants are easy to install, since they're almost plug-and-play).
AFAIK, routing wired traffic to a WAP would work, since access points are basically wireless versions of hubs. But as you may already know, the wired connections will be limited by the relatively lower bandwidth of wireless.
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
You need a wireless bridge.
Grumpy
Reply to Grumpy9117
There are 969 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
