Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Need Graphics card upgrade help-Yes I tried the SEARCH
Forum Graphic & Displays : Graphics Cards - Need Graphics card upgrade help-Yes I tried the SEARCH
Hello,
I had my Computer built in Dec. of 2002 and it has an ASUS P4B533 Motherboard w/ 1 AGP slot w/ a Siluro GF4 TI 4600 128 MB Nvidia video Card. On my Bday I got Call of Duty 4 and it says I need at least a Nvidia Geforce 6600 or better so I go on Ebay and hunt around and see that there are AGP 1x,2x,4x, and 8x. I asked those on Ebay and they were of little help/knowledge and said I had to get a card just like mine but there were no 1x/2x new cards out there...they were all AGP 8x. CAN I USE AN AGP 8X CARD? Sorry if this has been asked 1000 times but I am watching my twins and have read for a few hours and need a definitive answer from someone that knows.
Thanks in advance,
Scott :ange:
Sponsored Links
JS-44SDS wrote :
Hello,
Thanks in advance,
Scott :ange:
Just searched your board and it seems its a X4 board so you should be able to use a X8 card in it assuming this is your board http://www.serpentinemagoo88.biz/s [...] MB/Detail.
This may b eusefull to you in explaining compatability. http://www.playtool.com/pages/agpcompat/agp.html
Mactronix.
Reply to mactronix
The first link did not work but the second is more than sufficient.
Thanks again.
Scott
Reply to JS-44SDS
- 0 +
READ THIS FIRST (specificly Versions of AGP)
http://en.wikipedia.org/wiki/Accelerated_Graphics_Port
Check your motherboard (you have to uninstall the graphics card).
If the AGP slot has a 1.5V key it should be capable of runing an AGP 8X card.
If it doesn't have the 1.5V key, I found a review of this board here
http://www.computingondemand.com/r [...] 33-1.shtml
and they were runing a Radeon 9700 Pro on it.
If this is indeed your board you could try finding a 9700 Pro (ebay) but I don't know if it will run your game.
Good luck.
Reply to Andrius
Well I pulled my computer apart and checked and it appears that I have a 1.5v key. So I guess I'm in business.
Thanks for all the help,
Scott
Reply to JS-44SDS
- 0 +
look for the ATI 3850 AGP card if yo want the best you can get--it will be pricey, but for around $110 you can get a 2600XT that will do you some justice of the old system.
Reply to hesskia
There are 1169 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
