Hello!
I'm looking to put together my first ever PC & would love it if you guys/gals could look over my parts list & let me know if I'll run into any problems.
Some info: this is a budget gaming rig which I'm trying to keep under $700 total (before rebates), I use a 19" 5:4 LCD (1280x1024), I already have an OS. I don't intend to future upgrade the rig much, but I do anticipate doing some light over-clocking (taking the FSB up to 400).
Case = Rosewill R604-P
http://www.newegg.com/Product/Produc...82E16811147059
CPU = Intel E6550
http://www.newegg.com/Product/Produc...82E16819115030
Graphics = Palit 9600GT 512 MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814261002
HD = Seagate 250GB SATA 16MB Cache
http://www.newegg.com/Product/Produc...82E16822148262
PSU = Antec Earthwatts 500W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
Mobo = Gigabyte GA-P35-DS3L
http://www.newegg.com/Product/Produc...82E16813128059
Cooler = Arctic Cooling Freezer 7 Pro
http://www.newegg.com/Product/Produc...82E16835186134
RAM = G.Skill DDR2 800 2GB
http://www.newegg.com/Product/Produc...82E16820231098
Optical = Samsung DVDr 20x
http://www.newegg.com/Product/Produc...82E16827151155
Extras = 120mm fan for front of the case
The total on this would come to $680 after shipping. I'm hoping the 500w (34a on 12v, made by seasonic) will suffice just fine.
What do you think of the build, will I run into any hardware conflict issues? Any other sage advice?
Thanks!
CPU = Intel E6550
Thanks!
