There are better options for the price. If you want to use an AMD cpu, get the 5000 + BE, easy to OC and is under $90 US. I would get and Asus or a Gigabyte mobo. Even though I am using an AMD, my next build will probably be Intel based. Not biased one way or the other as far as cpu's go.
Unemcumbered by the thought process
Antec 900 Ausus M2N 832 SLI Vista Premium (AM2) AMD 5000 (Black Edition) 3.2 Ghz, 2 GB Patriot EPP 6400, 2 - 320 GB Seatagate (RAID 0), Radeon X1900 GT, Antec Tri Power 550 watt, Vista Ultimate 32 bit
