Nvidia nview problem
Hello, to whom who can help me..here is the situation...after i formatted my pc and install motherborad driver and other basic programs i needed..suddenly an error is constantly popping up every time i restarted my pc, the error says that "nvidia nview wizard version 110.29 encounters a problem" and an option button wether to "send" or "dont send"..what can i do to fix this problem?
1 answer Last reply
More about nvidia nview problem
  1. Delete video drivers, reinstall current video drivers from the computer manufacturer's website. You can download the latest drivers from the motherboard manufacturer.
    You will need to turn off the antivirus and firewall when installing new drivers. Then restart and turn the antivirus and firewall back on.
    Sometimes the motherboard manufacturer will recommend you install the drivers in a certain order, one at a time, and restart after each driver is loaded. Contact the board manufacturer for this info.
Drivers Nvidia Basic Windows XP
