Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Which power connectors for 8800 GTX SLI
Forum Graphic & Displays : Graphics Cards - Which power connectors for 8800 GTX SLI
Hi there,
Have a Jeantech 1000w psu and 2 x 8800 GTX. The connection on the back are:
http://www.xsreviews.co.uk/images/ [...] e-Cons.jpg
Which sockets should I have the gtx's connected to?
Crysis and some 3d apps crash after about 1hr of play. Could this be a psu issue?
Thanks
NevyNev
Sponsored Links
hi
You should have the 4 green pci-express connectors, connected to your video cards.
Hard to say about the crashes. You have a psu that supports two video cards.
What kind of crash do you meen?
Does it reboot by itself ? does your machine just freeze?What operating system are you using?What is it doing?
What are your machine specs?
regards
Laserman
Message edited by Laserman1 on 04-09-2008 at 02:17:52 PM
Reply to Laserman1
- 0 +
ASUS P5N-T Deluxe
Intel Core 2 Quad Pro Q6600 Energy Efficient SLACR 95W Edition 2.40GHz (1066FSB)
OCZ 4 GB RAM PC2-8000C5 1000MHz ReaperX
2 X 8800 GTX
1000W PSU
Raptor X 150 GB
Windows XP Pro 32-Bit
It hangs in Crysis, image freezes, sound stutters for few secs more then loops a sound until manual reboot. Ntune Stability test used to run but now the image comes up but the characters don't move, If I press stop it does so, if I drag the animation window it crashes to BSOD with nv4_disp.dll error.
Thanks
Reply to nevynev
- 0 +
Checked cabling all connected right.
Hmmmm?
Thanks
NevyNev
Reply to nevynev
nevynev wrote :
ASUS P5N-T Deluxe
2 X 8800 GTX
1000W PSU
Raptor X 150 GB
Thanks
[:mousemonkey:2] How many driver versions have you tried?
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
hi
I would update to latest drivers. im running 169.28 drivers. http://www.nvidia.com/Download/Find.aspx?lang=en-us
Test each vid card one by one.
Do a memtest.
Update sound card drivers.
Make sure if your not running two screens that your video card setting, in the nvidia controle panel , (MULTI-DISPLAY/MIXED-GPU) is set to single display mode,
(extension) limit set to off,(error reporting) set to off,(SLI performance mode)set to single gpu,(comformant texture clamp) set to use hardware.
My specs:
CPU E6700 @ 2.66ghz OVERCLOCKED TO 4.2ghz
VAPOCHILL LIGHT SPEED PHASE CHANGE COOLING - 52 *c
OCZ PC 8500 DDR2 RAM 2g ,AIR COOLED BY OCZ XTC COOLER and overclocked to 1166mhz
Asus P5N32-E SLI MOBO, VOLTAGE REGULATORS AND CHIPSET, WATER COOLED by KOOLANCE
2X 300g MAXTOR HD
2X 8800 BFG ULTRA, WATER COOLED BY KOOLANCE
KOOLANCE INTEGRATED WATER COOLING PC CASE
DELL 30" LCD
1000w psu antec modular
windows xp pro 32bit
Regards
Laserman
Message edited by Laserman1 on 04-09-2008 at 07:57:57 PM
Reply to Laserman1
There are 519 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
