2x MSI N9600GT 512
@164.99 each, (144.99 after rebate) so x2 =
329.98, (289.98 after rebate)
EVGA 132-CK-NF79-A1 LGA 775 NVIDIA nForce 790i Ultra SLI DDR3 ATX Intel Motherboard
@349.99
Intel Core 2 Quad Q9300 Yorkfield 2.5GHz 6MB L2 Cache LGA 775 95W Quad-Core Processor
@279.99
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1600
@376.99 (326.99 after rebate)
Thermaltake Armor Series VA8003BWS
@169.99 (144.99 after rebate)
OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply
@124.99 (89.99 after rebate)
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
@109.99
ASUS Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 14X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner with LightScribe
@36.99
BenQ G2400W Black 24" 5ms DVI HDMI Widescreen LCD Monitor 250 cd/m2 1000:1
@389.99
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD
@99.99
Total Cost w/o monitor before rebate:
1878.91
After rebate:
1728.90
w/ Monitor:
2118.89
Is there anything I skimped on that will bottleneck my system, and is there anything I went overboard on? Namely, do you think it's worth the DDR3 upgrade and the resulting mobo upgrade? That's at least a couple hundred dollars US price difference, is the performance worth it?
I figure it also leaves me with a mobo slightly more future-proof as well to upgrade the processor and RAM down the line.
Thanks in advance.
EDIT: The prices listed are quoted from newegg.com at the time of writing this.
@349.99
@279.99
@109.99
@36.99
@389.99
@99.99
1878.91
After rebate:
1728.90
w/ Monitor:
2118.89
Thanks in advance.
