Feel the Love & Check Our Lists Twice
hi, do u think that corsair 620hxeu is enough for 9800gx2? (with 1x WD640aaks, asus p5e, e8400 /or q6600 still not sure/, corsair 2x2048 1066ddr2, 1x DVD) is case 430 x 190 x 500 mm (H*W*D) (http://www.thermaltake.com/product/chassis/midtower/swing/vb6000bns.asp) big enough for 9800gx2? thanx
That PSU will be more than enough... However, im not sure about the case... those GX2's are pushing 11" long and i think youll find will struggle to fit.
For this kind of power you need to spend money on a full sized case like the coolermsater Stacker 831 or at least the Cosmos.
You do not really need a case as large as a Stacker 830, all you need is a case that supports extended ATX which will give you the extra room.
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
