HEYYYYYYY MODDS? Can we get a SPEEDSTEP STICKY already?
@OP its called speedstep. Its normal. You can turn it off if you want but it will make your cpu run max when idleing, thus keeping your idle temp hotter.
Did you notice when you made the thread, it says have you tried a search? Next time try it. Its amazing how it works.
C1E is the multiplier setting, and EIST is the Frequency setting I believe.
This is what happens when nobody reads their f****** manual Or are too lazy to use a search engine . They just come in places like this and expect someone else to figure out their problems for them .
And this is only gonna get worse as there are more and more n00bs like this who are joining the enthusiast scene ...... They should all buy Dell's and call their tech support with questions like this
