I had this problem
http://www.tomshardware.com/forum/258487-31-nothing-screen-graphic-card-motherboard-problem#bas
So I ordered the same motherboard again.
The only concern is resetting the ARCTIC COOLING Heat sink on the Q6600 Processor.
I bought the ARCTIC COOLING Freezer 7 Pro 92mm before because it already had the heat sink goo on there. (Easier for me even it wasn't the greatest).
I'm assuming that I'm going to need to get that old goo off (both the Heat sink and the processor) before apply new?
Whats the easiest way (with things around the house) to clean this?
Once the everything is back together, I now I need to let it "set" up. Can do that with the Motherboard on its side (The tower it stood up) or do I want to leave it flat for a while?
Thanks!
Thanks!
