Tom's Hardware > Forum > Overclocking > Motherboards > Is my parts bottleneck ?
Forum Overclocking : Motherboards - Is my parts bottleneck ?
I got A-data 800mhz
and I got an Q9300 CPU from intel and want to OVERCLOCK to 3.6ghz or 3.7ghz with aftermarket cooler
I try to oc it , but the max I can go is 3.2ghz 426 x 7.5 FSB 1.35v , memory @ 1023mhz 2:1 ratio 5-5-5-15 timing 2.1v ( default is 800mhz )
I got asus p5e motherboard
should I get better ram for overclock ?
I was planning to get
http://www.newegg.com/Product/Prod [...] 6820227347
^ 1200mhz
or
http://www.newegg.com/Product/Prod [...] 6820231166
^ 1066mhz
which 1 should I buy ?
Thanks
CK
Sponsored Links
go for 1200mhz but before u do that first see how far u current ram can go, try 2.3v and keep the same timings and i bet they can hit 1100mhz+.
Reply to richardscott
Max i can go with my ram is 1066mhz , but it will auto reboot b4 loading into windows xp
Reply to enyceckk101
well def go with 1200mhz memory
Before you go off and buy memory first wonder if it's worth buying memory? In real life applications there is no difference between 1066 C5 and 800 C4. Also are you sure your memory cant go higher? My DDR2-800 modules wouldnt go above DDR2-1030 C5, but as soon as I set DRAM CLK SKEW to advance 150ps I can happily run DDR2-1200 6-5-6-15.
Reply to Priv
I tried alot of setup and tweaks , I still can't get my ram any higher than 1066 without auto reboot
i want 1200mhz or 1066mhz so i can overclock my cpu ( if memory really bottleneck my cpu )
1066mhz and 1200mhz is almost the same price ( with rebate )
There are 612 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
