I am looking to build a new system and would like some advice on what motherboard I should purchase. I plan on purchasing the following components.
Intel Q6600 Quad core cpu and EVGA 512-P3-N808-AR
GeForce 8800GT AKIMBO SuperClocked 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Memory - Whatever is compatabile with the motherboard, DDR2 should suffice, but ddr3 would also be fine.
I am not looking to overclock anything, but would like the capability to upgrade to a better cpu sometime down the road. I guess my real delema is finding a good motherboard the will support PCI 2.0 x16. I would really like to purchase a cost effective motherboard, somewhere under $200, I just don't know enough about motherboards to know which one would be best. I am also not sure if I want to SLI the videocard I am purchasing down the road or just purchase a better card with a newer GPU in a year. I am using this machine for gaming.
Thank you for your adivice and any constructive critisism.
