I need help picking a good cooler for my setup. I plan on moderate overclocking eventually.
MOBO - GIGABYTE GA-EP43-DS3L LGA 775 Intel P43 ATX Intel Motherboard - Retail http://www.newegg.com/Product/Prod [...] 6813128347 $84.99
Video card- POWERCOLOR AX4850 512MD3-DH Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail http://www.newegg.com/Product/Prod [...]
Ram- CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C5 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
HD- Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
Case- APEVIA X-SNIPER G-Type X-SNIPERG-BL Black / Blue SECC Steel ATX Mid Tower Computer Case - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16811144237
Power- APEVIA ATX-AS600W-BL 600W ATX12V / EPS12V SLI Ready Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817148025
Cpu- E7200 - E8500 or maybe a E5200/E5300 depending on what deal I can get. So I need a fan that will work for either if there not the same. Like I said I only plan on doing moderate overclocking if any at all and I rather have the cpu installed now rather then having o pull everything out again. Plus its better to be safe then sorry.....Basicly all I am looking for is a cooler a step or two about stock....Thx in advance..
